Question about Lexmark Wheelwriter 15 Series II Typewriter
IBM Wheelwriter 10 Series II Typewriter
The thing that's supposed to move to strike the letter against the paper isn't working. I press a key, the letter wheel turns but nothing ends up on the paper. I love this thing and hope I can fix it !
  • Lexmark Master
  • 3,594 Answers
There is a plastic cap on the end of the print solenoid plunger whichis probably broken. They are available fron us for 15.00 including postage but can be a little tricky to install
DickyO
Posted on Dec 09, 2008
Where is the TYPEWRITER SOLENOID on a IBM Wheelwriter 6 Series II
The "print" solenoid is what hits the hammer that hits the printwheel and makes it type on your paper. If you remove the ribbon and look straight down in the carrier on the left side you can see the solenoid. It is below the blue piece of rubber that sits on the hammer arm. The end of the solenoid is supposed to have a cap on the end of the plunger. This cap gives a specific clearance so when it is activated, it hits the hammer arm to propel it forward to strike the printwheel.
Apr 28, 2014 | IBM Wheelwriter 6 Typewriter
Ibm wheelwriter won't strike. Ribbon is good. Wheel is working. Carriage is moving. Just not striking. I dusted & cleaned as well as I can but to no good.
I HAVE AN IBM WHEELWRITER 6 TYPEWRITER THAT WONT STRIKE THE LETTER. EVERYTHING ELSE WORKS? CAN YOU HELP ME FIX IT?
May 10, 2010 | Office Equipment & Supplies
When typing, all of the letters do not print,
There are two possibilities, Most likely the print solenoid cap is broken but the solenoid may just be gummy. The sol. is just inside the L. printer side frame just L of the selection motor, just in front of and directly below the small blue rubber damper. Spray some WD40 on the rear of the solenoid. If that dosen't help we sell the solenoid cap with shipping and instructions for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Apr 29, 2010 | Lexmark Wheelwriter 10 Series II...
Wheelwriter 6 typewriter hammer no longer strikes
It is pretty common for the pad on the solenoid to strike the keys wears out, and for the batteries to be dead for the memory. Your machine probably needs a good cleaning, oiling, and a new pad for the striker. about $100.00 in the shop.
Jun 30, 2009 | Office Equipment & Supplies
Letters and numbers not printing correctly
It sounds like you have a damaged printwheel. Get a new one and try it.
DickyO
Apr 28, 2009 | Lexmark Wheelwriter 15 Series II...
On my IBM Wheelwriter 6 my Code Cap does not work.
I found the owners manual and turned off the language key. This let everything work as it was suppose to.
Feb 05, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Selectric II
Yes. From not being used in so long It needs a chemical cleaning or washout and lubrication. It may need a part or two also. Everything is gummed up. I have been repairing selectrics for 35 years. Lawrence
Apr 20, 2008 | Lexmark Wheelwriter 15 Series II...
Wheelwriter 6
You may need a ribbon motor or motor board, however on the older wheelwriters sometimes the gear mesh gets sloppy and gears jam tooth for tooth. Try moving the ribbon lift gear/cam on rt. side of the carrier by hand with the machine off if it won't move that's the trouble. Wiggle it back and forth and it may free up.
Dec 20, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
Lexmark Wheelwriter 15 Series II Typewriter Logo
239 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
