Question about Casio Exilim EX-S880 Digital Camera
My casio exilim s880 is playing up
Hi when i put my fully charged battery into the camera a flashing red led starts and the camera wont turn on? iv tryed a new battery but this dose the same any ideas?
  • 7 Answers
Here's what I found and it actually worked after about 7 times. Others said they had to do it about 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Posted on Aug 05, 2009
My Casio Exilim EX-S880 wont turn on. Battery is dead but the camera wont charge on the charger. The red charger light is flashing when then camera is placed on it. This red light used to stay on...
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
ylu1 writes:
what i did was...
hope this helps.
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
My casio ex s880 won't turn on. when i put it on the charger cradle the red light flashes (it normally doesn't flash). Also when its on the charger it'll let me view my pictures on my memory card it just...
It happened to me. I fixed it by luck . Here is my way . fully charge the camera till the led turns green. "IMPORTANT" unplug the power of the charger first, then remove the camera from the cradle . Then I pressed power button, it worked.
Wish good luck to you too
cz
Jul 18, 2009 | Casio Exilim EX-S880 Digital Camera
My Casio Exilim EX-S880 wont charge. when i put on the charger the red light blinks but it is not charging.
I had this exact same problem. Here's a solution. I had to do it about 7 times and others on Amazon said they had to do it about 20 times. But it does work! My light is a solid red as we speak! Good luck!
ylu1 writes:
what i did was...
hope this helps.
Jul 16, 2009 | Casio Exilim EX-S880 Digital Camera
When the battery is in the charger it flashes red & won't charge, have no idea what problem is! Have casio exilim lithium ion NP-20 battery & a casio exilim 7.2 megapixels camera. Can't turn camera...
I called casio and they told me that when you have a red flashing light on the charger it means the lithium battery is no longer any good. They offered to send me one free of charge. It's been several weeks and I have yet to receive it.
Jul 08, 2009 | Casio EXILIM Digital Camera
The red light that indicates its charging keeps flashing
How old is the battery? Keep in mind they aren't meant to last for more than a year or two, regardless of how often they're used. Generic replacements are actually inexpensive these days. Here's some from Amazon:
http://www.amazon.com/s/ref=nb_ss_e?url=search-alias%3Delectronics&field-keywords=s880+np-20+battery&x=12&y=22
Jun 06, 2009 | Casio Exilim EX-S880 Digital Camera
Casio exilim ex-s880 wont charge battery has been replaced and when on the charging dock charging light just blinks
I had the same problem. Here's what I found that worked for me. I had to do this about 7 times but others that I read had to do it about 20 times but worked for them as well. Good luck!
ylu1 writes:
what i did was...
hope this helps.
Feb 22, 2009 | Casio Exilim EX-S880 Digital Camera
Casio Exilim EX-S880 I put my camera on the charging dock and the orange light comes on. After about 15 seconds it starts flashing. I can't turn my camera on at all. The only way I do is to view them on...
if you try pushing the battery in further it might turn on, if that doesn't work just get a new battery, but make sure to take it out when you aren't using it or this will happen again.
Jan 29, 2009 | Casio Exilim EX-S880 Digital Camera
Battery charging
I had the same problem, called Casio, and -- like the first solution -- they'll send a battery.  So, folks, it's a manufacturer-originated problem and kudos to Casio for owning up to it (they admitted it on the phone) and for sending the solution, a replacement battery.
Dec 23, 2008 | Casio Exilim EX-S880 Digital Camera
EX S880 not charging
you have a bad battery common when the battery sits to long with out being charged they are like 5 bucks on ebay.
Aug 05, 2008 | Casio Exilim EX-S880 Digital Camera
Battery will not charge
Here is how you fix the problem (without using a 9V battery method...).
The battery doesn't charge because it's been fully discharged.
What you do is you put the camera into the cradle. Now you see that the Red LED comes on solid for a while. It's charging for a few seconds. Then it starts blinking. When it does that - TAKE THE CAMERA OUT of the cradle.
Now put the camera back and repeat. Do this six or eight times. Each time what's happening is that the battery is getting a tiny bit of charge. After 8 times the LED will come on red and stay solid red.
Bingo, no problem!
Jul 10, 2008 | Casio Exilim EX-Z57 Digital Camera
Casio Exilim EX-S880 Digital Camera Logo
99 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
