Question about Toshiba TheaterWide 46HM94 46" Rear Projection HDTV
No picture or sound
I got this tv from an auction. It has no sound or picture, I replaced the bulb and still has the same problem. A green light come on and a red flashing light, could you help?
  • kaseyjack Feb 08, 2008
    while watching tv, picutre went back, sound went out. On and off buttons flash back and forth...now what???
    D
    Genius:
  • 1,139 Answers
Hello till, First you will need a schematic, and some equipment, if you do not have a background in electronics. You will need to take the unit to a TV repair shop. Having said that I believe your problem is in the high voltage power supply section. You will need a schematic to which to compare the measured voltages to, a multimeter to measure the voltages, and access to an oscilloscope to measure the wave forms on the DC voltage line to make sure ripple voltage is at a minium or not present at all. Reading the error lights is ok as a begining but nothing beats troubleshooting.
Posted on Oct 04, 2007
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
Wd60c9 lights blinking green sometimes,then yellow and finally red and no picture for any significant length of time
2 possibilities. First, the bulb which allows you to view your picture could be burned out. If that is the case, your tv will turn on and you will hear audio but no picture. $85 for a new warranted bulb from Shopjimmy.com. Second possibility. If your TV is on with no picture or sound, you probably have a light engine problem.$325. I don't think it's your light engine. Just don't have enough information. Check the first possibility first. The bulb takes less than 5 minutes to replace. Don't buy just the bulb, buy it with the housing. It doesn't cost more, it costs less and saves a ton of aggravation. Don't touch the bulb with your fingers, use latex gloves when working on electronics.
Feb 23, 2013 | Mitsubishi WD-60C9 60" DLP HDTV
Magnavox tv when the power button is pressed the green light comes on but nothing else happens; there's no picture or sound or nothing; but the green light simply stays lit (no blinking).
first, press the channel -/+ button on the TV. If that doesn't turn on the TV, then it means you have to replace the bulb of your TV. The bulb is most likely dead.
Replace the bulb and your TV should be restored.
Let me know if you need further assistance.
Regards.
Aug 12, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a sony tv model kdf-50e2000,and it has a problem with the picture going blank,the only light that on or flashes is the green (POWER) light. when turning the set on the green light blinks as it...
You tv used lamp XL-2400 or also known as F93087500. It is very common for this bulb to fail and have the exact symptom you are experiencing. I cant count how many times I have seen it.. Replace the lamp with either the exact Sony or an OEM and you will be back in business..
Good Luck!!
Dec 28, 2010 | Sony KDF-50E2000 50" HDTV
No picture but normal sound.
projection bulb needs replacement
Aug 11, 2008 | Televison & Video
Keeps going black and coming back on - green light blinks
Our tv is about 2 1/2 yrs old and did the same thing we had to replace the bulb and bulb driver board this fixed the problem
Jan 27, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Green flashing light - no picture
If the green power light is blinking and you have no picture, then your light bulb has burned out and needs to be replaced. It is not a cheap bulb to replace. If the TV is less than 1 year old it should be covered by the warranty
Nov 03, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Toshiba TheaterWide 46HM94 46" Rear Projection HDTV Logo
54 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
