Question about KitchenAid KSM150PS Artisan Series Stand Mixer
KitchenAid KSM150PMC starts then stops Mixer turns on but shuts off within seconds. Beaters turn slowly then stop. The mixer's just over a year old. Are there reset instructions for this model? I cannot locate the receipt for an exchange.
  • jhauck11 Dec 13, 2008
    Hey "Mike"...why does every "Mixer problem" have a response but mine? This site is a joke! It's just a scam! You won't get any useful answer unless you pay. Can I sign up for your Premium Assistance plan...please? I'm sure you'll be able to tell me something that KitchenAid can't.
    No "solution"...no "comment"...NO SH*@!
5 Suggested Answers
  • 12 Answers
SOURCE: KitchenAid Mixer Squeaking
I would first get some canned air. Spray out the area around the Shaft. This is to make sure no harden food is up there. After that is clean spray some cooking spray "PAM"in the Shaft area. This should help. Good Luck
Posted on Feb 11, 2008
SOURCE: black stuff wiping off beaters of kitchenaid mixer
If it's just the wire beater attachment, then it's possible it's oxidation from the metal/aluminum. Did you put it in the dishwasher? The manual says not to put the wire beater in the dishwasher. Hope that helps.
Posted on Jan 15, 2009
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. bakerboy49203@yahoo.com. Let me know if it works.
Posted on Mar 21, 2009
hslincoln
  • 235 Answers
SOURCE: Kitchenaid mixer. Top is loose so it bounces when
Hi MJANKOW520. I?m going to assume your KA mixer is a ?Tilt-Head? mixer. You don?t say specifically. Based on your description of the symptoms you mixer exhibits, I would say that your head locking mechanism (or a component) of it is either broken, worn or loosened due to normal wear and tear and need to be readjusted (or repaired) for it to keep your mixer head stationery. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, try K45SSW, and select the file listed under Parts List (check to see it this matches your mixer model). This parts list manual provides an exploded view for the disassembly and reassembly of your mixer, along with all the part name and numbers. Turn to page3, titled: Base and Pedestal Unit. You?ll want to focus on Illus. #9, Link & Lever Latch assembly, which locks the mixer head to the pedestal when run your mixer. Check to see if something is just loose, exceedingly worn or broken. If something has broken, you can order replacement parts and install yourself. As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping. Once apart you can check for any other unseemly wear and tear on other mixer components. It can be messy but quite gratifying to diagnose and repair your mixer yourself. Finally, here's a link to an excellent site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html If you feel this is beyond your capabilities and would be too difficult to do yourself you can take your mixer to a local small appliance repair shop and have them troubleshoot and fix your mixer. KA Customer Care can provide you with the name and phone # of the closest authorized KA repair shop in your area or you can do a Online web search, but be sure to get at least three estimates before deciding to commit to one repair shop. Good luck. I hope this helps. Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Posted on Dec 02, 2009
SOURCE: KitchenAid Artisan KSM150BOB Stand Mixer won't start
It could be very easy. It maybe you have a the brush in the wrong way round or they have simply run out. They are on the sides under the black plastic caps. Although they will fit in the hole any one of 4 ways round, there is a key on one corner which means it will only go in one direction. Use a torch to look into the hole before you put it back in.
They shoud look like this : brush
Posted on Jan 24, 2010
Kitchen aid khm3wh beaters will not stay in mixer
I fixed mine (my wife's). Kitchenaid 3-Speed Hand Mixer KHM3WH. Here's how I did it.
This is a pretty old mixer. My wife bought it at a thrift store for $1. She brought it home, we found the beaters and whisk beaters on eBay. Paid $34.00 for both sets of beaters, but when we received them we found they would not stay in the mixer. Oh we also bought the alternative/replacement beaters from Sears, parts online. I don't think those will work with my fix. However with some $0.92 rubber washers from Lowe's and a heavy duty paperclip I fixed the mixer, and it works flawlessly. Maybe some stainless steel wire would be a better, more permanent fix.
Apr 30, 2012 | KitchenAid KHM3 Classic Hand Mixer
The mixer motor runs good but beaters turn slowly and will not turn when the beaters are under load. Is this a clutch, gear or what? Any ideas? Do you think it can be fixed?
I found out by marking the shaft and gears with a magic marker that the main shaft that drives the sun gear was slipping. My cure was to drill a 5/32 hole a 1/4 inch down through shaft and drive a 5/32 roll pin through it and it solved the problem. See my picture.
Nov 21, 2010 | KitchenAid KT2651X Epicurean Stand Mixer
Kitchenaid hand mixer (about 18 years old) works great, but the beaters keep falling out
ROTHL, you must be joking. 18 years?!? You're lucky it still turns on. In the last 18 years (I do a lot of cooking), I've gone through 5 hand mixers.
Buy a new one.
Oct 19, 2009 | KitchenAid Food Mixers
I have a Kitchenaid Professional 5 Plus Mixer beaters won't turn
It sounds like it has been overloaded and the worm gear has been stripped. You will need to take the head apart to confirm this.
Jun 24, 2009 | KitchenAid K45SS Classic Stand Mixer
W!ill not start up
Hi Karl. Have your mixer repaired by a shop that has experience repairing Kitchenaid mixers. Don't think for a second that a new mixer will solve your problems. The new Kitchenaid mixers are not as durable as your old one and are made with an absolute minimum of quality. Quality costs money! ricardok45
Mar 16, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Turntable does not turn. Motor runs. Beaters work.
I have the same one, and the turn table has never turned on it's own. from looking at the bottom of the stand, i think the mixers are supposed to turn the bowl, so i just give it a little turn, and the mixers kinda take care of the rest. BTW, i got 2 sets of beaters with mine and i dont know what the second set is for, do you? contact me at rawemo@hotmail.com
Feb 18, 2009 | Sunbeam Food Mixers
Kitchenaid k45ss won't turn on
if you remove the top you will find a tiny fuse wrapped in a black band on the left side from the back. It connects two white wires which power the top-side motor brush. Most likely this needs to be replaced. You can check by bypassing it with roach clips or a copper wire. Unplug the machine first and be careful!
Jan 25, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
Mixer stuck
You will have to have the transmission serviced. sounds like the gears were ground out. you can do the service work yourself its not to difficult.
Apr 18, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
74 people viewed this question
Top KitchenAid Food Mixers Experts
Custom Exchange
Custom Exchange
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
