Question about Whirlpool Calypso GVW9959K Top Load Washer
CLEAN SOFTNER DISPENSER
I HAVE A WHIRLPOOL WASHING MACHINE (toploader). The thing turns in the middle have a softner didpenser on top. I pull it off and looks like a glass with a top on. It is very dirty . How do I get the cap off to clean it inside.
Thanks Nic
    President:
  • 3,113 Answers
It snaps in. No need to clean it as it cover the agitator cams or dogs.
Posted on Mar 03, 2010
The water isn't filling into water softner for setting up
Depending on the washing machine, it is supposed to have a gizmo inside the softner housing that triggers the water during the rinse cycle to flow into the softner dispenser. Sometimes, they go missing or are clogged with hardened softner. Open the door fully open and carefully prize the entire housing out. Clean it with hot water and put it back in. Some machines require the slide in tray be raised about 70 degrees (most common) and then pull out, others require a downward angle.
Mar 12, 2015 | Washing Machines
How can I remove the agitator to clean the liquid softner dispenser, it is clogged
you will have to remove plastic nut at top of aggitator to be able to raise the aggitator out of the tub hope this helps
Feb 29, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
How do you get the agitator to come out the fabric softner dispenser is filthy and all needs to be cleaned
By grasping just the fabric softner dispenser and wiggling it from side to side while pulling up the softner dispenser will come out to be cleaned.
GENE
Oct 13, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Cleaning the softner dispenser for Whirlpool Ultimate care ii
boil a pan of hot water and pou it down the dspenser slowly, this will melt and disolve the gunk, u may have to do this several times, it does work!
Jul 05, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Clothes stink
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softner dispenser
Small brush and plain water. Rub, flush, repeat...
If it's clogged where you can't get a brush, pour very hot water into it. Last resort would be blowing it out with an air compressor...
May 07, 2009 | GE Profile WPRE6100G Top Load Washer
Adding Softner
try taking the dispenser off and cleaning it might have a build up of old softner
Oct 15, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Water collecting in the fabric softner dispencer
you need to take out dispenser draw and clean out under tap
the softner dispenser syphons out and if channels are gluged up the dispenser will not empty
Mar 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
