Question about Christie Replacement lamp Projector Lamp for DS30 and DS30W Projectors.
I purchased a Christie ds30 online. Plug it in and pushed switch...nothing happened! Popped the top and saw the fuse was missing...replaced with a smaller fuse to be safe....turned on projector and heard several pops...came from power supply board....looks like the voltage regulator burned a lef right off and several of the surface mount resistors poped also.....do you think there is any chance of saving this thing? any schemetics so I can find the values of these micro compoments? thanks for your help, Ezra J Mulheron
  • 62 Answers
Um, regarding the projector power supply that went foo, yes there is a chance of fixing it, is it worth your time and money? Probably not. I would take it to a repair shop before ditching, but plan on purchasing a new unit. Replacing power supplies is possible, but on high-end electronics like projectors, I wouldn't personally reccommend it.
Posted on Dec 09, 2008
Bosch table saw GTS1031 won't start.
In case of this kind of questions you can only advise someone to go back immediately where they have bought the tool for warranty or exchange or money back.
No other suggestions but few years to late to give the only right answer in this cause of question.
Aug 29, 2014 | Bosch GTS1031 10-in Portable Jobsite Table...
When I turn on my Christie DS30-projector, I get a message telling me that the lamp only has 10% left, even though I recently changed it. Is there a way to fix this? It clearly isn't at 10%.
You probably didn't reset the lamp timer after changing the lamp. All I could find in the user's manual is this: In the "utilities" sub menu, reset the lamp timer.
Jan 26, 2011 | Christie DS30 Multimedia Projector
My very old Craftsman 10" Table Saw does not power on. While rip cutting some plywood, I errored and caused the blade to bind. Before I was able to power off the saw, the motor stopped. I thought I had...
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Aug 13, 2010 | Craftsman 10" Table Saw
Set timer nothing happen after pushing start button
Check 220v voltage at the wall plug.
Check door switch
In back pull off panel and check Thermal fuse at top of element case
Check white fuse lower left on return air (2 wires )
Leo Ponder
imufo2@sbcglobal.net
Jul 28, 2010 | Kenmore 64672 Electric Dryer
Can't start my Chain Saw Husqvarna 350.
The fuel may have been replaced, but is the fuel filter clean or is the fuel line cracked? Even though you cleaned the spark plug, did you check to see if it has a spark? If not, maybe a new spark plug or check the wire to make sure there is nothing blocking where the wire and spark plug connect. Is the air filter clean? Just a few more things to check out...
May 14, 2010 | Husqvarna Chain Saw 20" Bar
Washer will not turn on. The knob moves but nothing happens when I turn it on. I've checked the breaker, the water, the plug/outlet, and hoses. Everything looks fine. But nothing happens.
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 05, 2009 | Whirlpool LSR9434PQ Top Load Washer
2002 vw cabrio - top will not work
you need to make sure car is in park, parking break is on, and ALL windows are DOWN, then you should be able to put the top down. do the same thing to put the top back up too. hope this was helpful.
Mar 28, 2009 | 2002 Volkswagen Cabrio
Elcectric self cleaning Kenmore oven directions needed
It was easier than I thought. I was watching the other postings scroll by and saw the answer, posted months ago, right in front of me. I was missing the last step...pushing the up arrow button.
Jan 29, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Christie DS30 power supply problem
the caps on the board dry out from excessive heat. the can no longer charge as fast as they once could. could also be the voltage regulator. same reason. you can replace all of the capacitors and regulators, or get a new ps.
Sep 04, 2008 | Christie DS30 Multimedia Projector
167 people viewed this question
Top Christie Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Oravetz
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
