Question about Kenmore Oasis HE 27087
Kenmore Elite HE 27087 fills water to max, drains then "oL" fault
My washer fills up to the max then drains and slowly spins for a few seconds and shuts off with an "oL" fault. Paid $70 for a Sears Tech to come out and tell the cntrl-elec board is the problem. Declined the quote of $568.25, and ordered the part myself. Changed it out and it still did the same thing. Performed diagnostics, step C1 failed. It filled up all the way then kicked out the "oL" fault. Turned it off then the "F1" error popped up. Reinstalled original board and will try to return the one I ordered. Followed the troubleshooting guide for the "over fill" problem still got the same problem. Pressure hose seems to be in good shape. Any other ideas???
  • BOYNISMO May 11, 2010
    WHAT'S THE COMPLETE MODEL NUMBER? 110.27087***?
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 18, 2010
Mid wash cycle shuts down and ol appears....laundry still soaking wet and washer shut off
follow this thread: http://appliantology.org/topic/37774-kenmore-elite-oasis-he-ol-error-code/
Mar 22, 2015 | Kenmore Oasis HE 27087
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Filling with water but not draining or spinning
Its not the water - it's the weight of the clothes. Remove some clothes and re-try.
If this doesnt solve - the ECU is failed and must be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2009 | Kenmore Washing Machines
Washer is skiping rinse and don't spin has code ol
be sure that both water sources are connected and turned on.
Sep 14, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Oasis HE 27087 Logo
99 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
