Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
How do I fit new diverta..
I have a Bissell Pro Heat 7920E carpet cleaner and the diverta flap arm broke. I have the new part but need advice on how to locate the arm into the spring loaded clip on the end of the diverta knob. Very limited space, can't get hand inside and don't want to do any further damage by pulling at plastic clips. Is there a trick to this?
Thanks for your help
Phil
  • jamesfoster4 May 03, 2009
    hi i just broke my mother-in-laws Bissell Proheat Elevator, i've ordered the new part but can't figure out how to put it on can you help~?
  • 32 Answers
Usually this can go one of two ways, very easily, or absolutely a pain. You will need needle nose pliers, and patience. When I am in the shop working on these machines, it's always a matter of not getting frustrated, and using eccessive force.
If there is a coil spring you will want to pull that back gently, and place the arm back into place, always be gentle and patient. Then you may have to use a flat head screw driver to push the arm into final position.. again.. be patient, and gentle... this is all plastic except for the spring of course.
I hope this helps.
Posted on Jan 21, 2009
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Directions for pro heat steam cleaner
If you go to http://www.bissell.com/customer-support/ and type in the specific model number of your Bissell in the space headed by "Find Replacement Parts & Download User Guides", it will provide you with a list of documents for your model. This is presuming that your model is not too old.
Feb 26, 2010 | Bissell Vacuums
Have lost my instruction manual for my bissell PROHEAT PRO-TECH 7920E pLEASE CAN YOU HELP ME J Mills
Bissell has online USER Guides... for your model
CLICK HERE you can click on the user guide under your model to download a fresh pdf copy
Happy Cleaning!
Dec 05, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Fitting diverta to a bissell 7920
take off main body 6 screws & fix from inside
Oct 27, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Fit a pump to Bissell proheat 7920e
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
wtqy
Jan 09, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Diverter knob & flap & gasket broke
You will have to pull the top cover off, it fits underneath unto the knob. When you see the bottom, you should be able to tell. The arm of the diverter goes thru the hole and then hooks onto the bottom of the knob.
Jul 21, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
179 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
