No sound My Mitsubish vs-507703 tv has no sound
  • cbrow24 Dec 09, 2008
    Yes' I have always had sound thru the tv speaker. I was watching a movie and the sound stoped.
  • Paul Hitchings
    Paul Hitchings May 11, 2010
    You likely have the speakers off. Did you try to connect TV to another external audio source like a receiver or surround sound system? Do you normally get sound through speakers in TV or speakers in your soudn system?
  • 62 Answers
So your sound doesn't work for TV now or while watching a movie? Can you try using audio out on TV to connect to other audio source? I wouldn't think that the audio coming in from TV would stop working, but if audio signal works through TV then the speakers are blown, maybe there is a fuse internally that blew, or both speakers blew at the same time, which is more unlikely. If you are comfortable removing cover, do so and check fuses and for other signs of failure like burn spots or melted solder. Please comment on the results. Also, with cover off, speakers can usually be accessed, so try testing them with another audio source. If speakers still work than TV audio is the problem, and could be difficult to replace on your own, but might be worth repairman. Of course, easier solution is to buy cheap receiver and speakers, I can almost gaurantee that would work. But always keep the receipts anyways ;)
hope this helps.
Paul
Posted on Dec 09, 2008
Need a replacement bulb for my mitsubishi vs-55601
Hi,a spares supplier should be able to help you , just do a wed search from either google or bing, for a Mitsubish spares supplier in your area
Jan 11, 2014 | Mitsubishi VS-55601 55" Rear Projection...
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
How do i hook up a itp 180b ilive sound bar to my mitsubishi tv
YOU SHOULD CONNECT IT TO THE AUDIO OUTPUT. YOU WILL HAVE TO TURN THE INTERNAL SPEAKERS OFF.
Nov 04, 2013 | Mitsubishi Mitsubish Wd73c10 73" 1080p 3d...
I need the code to set my tv watch modelF67997 for mitsubish tv and where to push the rt buttons because the watch is old and its no writing on it
Can you rephrase the question. It sounds like english is your second language and nothing makes any sense.
Oct 23, 2013 | Televison & Video
I NEED TO MOVE MY MITSUBISH VS 70709 UPSTAIRS AND I NEED TO KNOW HOW TO TAKE THE BASE OFF FROM THE SCREEN
This may be one of the models that comes apart--if it is on either side you will see two plastic caps--beneath are either regular bolts or L shaped ones you turn.
Most of the sets that had the feature needed the front screen removed first to do this.
If you do not see the black plastic caps (two on either side) it does not have that feature.
SD TECH
Sep 28, 2010 | Mitsubishi VS-70709 TV
When I attempt to turn on my 10-year old 60'' Mitsubish rear projection tv, the power light comes on for a few second and then goes off. Thus I can not power on the tv even after repeated atempts.
Hi, this is a common issue due to the age of this set. The internal power board has failed. You can fix this by replacing the internal power board. Its a single piece of circuitry that can be ordered and shipped to your home for a do it yourself or, you can call a service tech to do it for you.
Mar 09, 2009 | Mitsubishi VS-60607 TV
VS-50609 no picture no sound
Seems to be the power button is stuck on the tv itself
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi 52
will need model number and go to ctechnicians.com
Dec 22, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
