Question about Haier XQG50-QF80 Front Load Washer
Intermittent wash cycle
Sometimes the wash cycle will complete and water will still be in the tub, other times it will go through the cycle and drain as well, somtimes it will not go to the next cycle. agititation works but the final spin and or drain is intermittent....any advice?
    Problem Solver:
  • 16 Answers
If there is a filter on this model, make sure it is clean, a lot of fluff and other stuff can accumulate in the filter preventing the water from draining fast enough. Sometimes the pump can get blocked with the same effect. Tom.
Posted on Mar 09, 2007
SOURCE:
How do I fix my LG WF-T1391TP top loader washing machine, as water does not flush out after a wash cycle, sometimes after a rinse cycle?
sounds like the drain pump could be clogged up might wanna lay it on its backside and take the motor out and inspect it for any buildup inside of its self as this can/will damage the drain pump however if there is nothing there inside the drain pump then the pump needs replacing
Aug 24, 2016 | LG Washing Machines
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
Tip
Resolve Intermittent Drain in Dishwasher
<span>From the excellent description you give the most likely cause of this problem is the check ball and funnel in the soil collector.<span>It drains fine sometimes but sometimes it doesn't drain but the motor is turning. If the motor is turning in the drain cycle most likely the motor and timer are okay. The motor on this dishwasher runs one direction to wash and one direction to drain. You can listen for this but there is another more likely part causing this problem.</span><br /> <br /><br />The idea is that in the wash cycle the circulation of the water brings food particles into the chamber. In the drain cycle the circulation is reversed and the check ball is suppose to seal the funnel off so all of the food and soils go down the drain. If the check ball doesn't seal the funnel then the water will not drain but go back into the tub.<br /> <br /><br />Most likely your problem is with the check ball and/or funnel. There may be something in the chamber preventing the check ball from sealing the funnel all of the time. Sometimes it does but sometimes it doesn't.<br /> <br />The images below will give you an idea of where the soil settler is located. You can remove the toe panel but must likely you'll need to pull the dishwasher out to access it.<br /> <br /><span> </span><br />This is a job I'd recommend a technician do. The funnel , check ball and the soil settler/separator <a href="http://www.searspartsdirect.com/"> </a>. You will also need some RTV sealant but even technicians have difficulty with this repair and I suggest you let the technician get the headache.<br /> <br /><br />The check ball and funnel can definitely cause an intermittent drain problem.<br /> <br /><br />I hope this information is helpful resolving this problem.<br /></span>
on Jan 24, 2011 | Dishwashers
Tip
Resolve Intermittent Drain in Dishawasher
<span>The most likely cause of this problem is the check ball and funnel in the soil collector.<span>It drains fine sometimes but sometimes it doesn't drain but the motor is turning. If the motor is turning in the drain cycle most likely the motor and timer are okay. The motor on this dishwasher runs one direction to wash and one direction to drain. You can listen for this but there is another more likely part causing this problem.</span><br /><br /> <br />The idea is that in the wash cycle the circulation of the water brings food particles into the chamber. In the drain cycle the circulation is reversed and the check ball is suppose to seal the funnel off so all of the food and soils go down the drain. If the check ball doesn't seal the funnel then the water will not drain but go back into the tub.<br /> <br /><br />Most likely your problem is with the check ball and/or funnel. There may be something in the chamber preventing the check ball from sealing the funnel all of the time. Sometimes it does but sometimes it doesn't.<br /> <br />The images below will give you an idea of where the soil settler is located. You can remove the toe panel but must likely you'll need to pull the dishwasher out to access it.<br /> <br /><span> </span>This is a job I'd recommend a technician do. The funnel , check ball and the soil settler/separator <a href="http://www.searspartsdirect.com/"> </a>. You will also need some RTV sealant but even technicians have difficulty with this repair and I suggest you let the technician get the headache.<br /> <br /><br />The check ball and funnel can definitely cause an intermittent drain problem.<br /> <br /><br />I hope this information is helpful resolving this problem.<br /></span>
Washing machine won't spin in the spin cycle. The model # is GWL11US the serial # is EYN654081 I tried to get the date of purchase and couldn't ascertain that info. CAN YOU HELP!
check that ALL of the water has been pumped out you could have a partally blocked drain pump causing the water level pressure switch not to be satisfied that the tub is completly drained. If tub is NOT completly drained it wont spin but it will usually give you an error code try drain spin to see if that works draining it a second time
Feb 12, 2010 | Fisher and Paykel Washing Machines
At end of cycle washer is full of water..intermittent problem
You may want to remove the inner tub and check for a article of clothing, hanky, sock, wash cloth or small baby item lodged between the inner and outer tubs. It floats and sporatically blocks the drain hole when the unit is suppose to be draining. I agree with you that is it not an electrical issue. Check this and let me know what you find.....
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Incomplete wash cycle.
It sounds as if you have something acting as a flap causing the restriction. You should take the hose that leads from the tub to the pump off and see if there is anything just inside the tub. I have noticed that alot times you could have a coin that blocks the opening. You may have to remove the inner tub to remove anything in there
Dec 30, 2008 | Maytag SAV3655A Top Load Washer
Spin cycle does not drain water completely
the motor may have more than one copper windings to achieve high speed. power down, open the unit and continuity check the motor windings
May 17, 2007 | Kenmore 98702 Stacked Washer/Dryer
Haier XQG50-QF80 Front Load Washer Logo
141 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
