Question about Lexmark Z715 InkJet Printer
Instructions on how to install ink cartridges for Lexmark Z715 printer
    President:
  • Lexmark Master
  • 990 Answers
1,power on the machine
2,open tbe cover
3, you will see the carrier right in front of you
4, load your ink cartridgeat their right position
Posted on Dec 09, 2008
Why is my print lighter and hard to read at the top of the page but subsequent copies look fine. thanks, gene
Your cartridges may need to be cleaned. Follow the instructions in this article from the Lexmark website on How to Clean the Cartridges of the Lexmark Z715 in Windows. This will help improve the print quality for your printer. Also, make sure you are using genuine Lexmark cartridges. Thanks.
Feb 24, 2011 | Lexmark Z715 InkJet Printer
Wont accept #90 ink cartridge
It could be that your cartridge needs cleaning. Refer to these articles on:
- How to Clean the Cartridges of the Lexmark Z715 in Windows - How to Clean the Print Cartridge Nozzles and Contacts Manually
Also, make sure your cartridge is properly seated in the cartridge carrier. Turning off/on your printer might also help.
Feb 10, 2011 | Lexmark Z715 InkJet Printer
White lines through print jobs. installed new cartridges
It could be the cartridges in the printer. Maybe it needs cleaning. Refer to this article How to Clean the Cartridges of the Lexmark Z715 in Windows. If problem continues, reseat the cartridges. Or you can try to use a different known working cartridge to determine if the other is faulty. Thanks.
Nov 12, 2010 | Lexmark Z715 InkJet Printer
Lexmark Z715 printing faded color
you might need to go to the IBM website and find instructions for your printer and look up how to clean the printheads on your printer or just look up the manual that came whith the printer if it did come whith any
May 16, 2010 | IBM Lexmark Z715 InkJet Printer
Do I need a color cartridge to print in black ink
the paper was black or blank? i think you mean blank, the ink will dry out over time replacing the cartridges will most likely solve the problem, or for the cost of the two cartridges u may want to consider a new cheap printer.
Apr 23, 2010 | Lexmark Z715 InkJet Printer
Lexmark z715. paper comes thru with no ink in it. cartridge is full and appears to be installed oorrectly..please help
You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "All Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Turn the power to the printer "off."
2. Press and hold the "Paper Feed" button.
3. Press the "Power" button once while continuing to hold the "Paper Feed" button.
4. Keep holding the "Paper Feed" button until one sheet is cycled through.
5. The test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
May 05, 2009 | Lexmark Z715 InkJet Printer
Installation....
You can download the setup here from Lexmark.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+Z715
After you finish the download execute it and follow the on screen instructions.
Mar 20, 2008 | Lexmark Z715 InkJet Printer
Blank paper
That is the most likely cause.
Also under the cartridges, there are some ports and pads that may have dried out. In that case unplug the machine, and remove the cartridges, trickle some alcohol slowly to dissolve the sticky ink in that area. Place some paper towels under the print head area as you trickle in the alcoholl and allow it to drip into those towels. Then allow some time to dry.
The cartridges and those port areas can dry out or become very tacky.
Feb 26, 2008 | Lexmark Z715 InkJet Printer
Lexmark Z715 InkJet Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
