The serpentine belt tensioner is weak. Get a new one installed. For a quick fix go to parts store and get some belt dressing and spray it on the belt and pulleys.
belts squeal for only 2 reason
it's bad. the belt.
or the accessorym it drives is Seized.
i guess you never head of a 5buck stethoscope
and listen to the accessory bearings, ah, alternator front and rear
i hear, front crying for help. easy as child play.
sold everywhere cars parts are sold.
there is no need to guess, , answer use tools.
this was true in 1920 and now, belts then and now all can squeal.
in the old days we had many belts and could drop them
then comes, SERP belts. one for all.
we dont have 1.3 swifts here, so cant see belt routing.
Hi Tereza.
has anybody checked the pressure hoses of the steering and especially the one which has the one way valve inside whether is the one with the problem?
Possible solution may be a new serpentine belt. When you turn the steering wheel it is an added torque/tension against the belt from the power steering drive pulley. A worn and dry belt may tend to squeal as the extra grip on that pulley is applied. You would have to pinpoint just where the squeal is coming from to be sure the power steering pump is the origin of the noise. There may also be other reasons if its due to a worn out belt, idler and tensioner pulley's could be making noise as well.
excess mechanical drag from the pump can cause the belt to slip and squeal, but before focusing on the pump I'd check the condition, tension and alignment of the belt. I might even try cleaning all the pulleys with an aerosol brake cleaner and install a new belt, particularly if the current one has more than 50,000 miles on it. It might be that the squeal is coming from or caused by a different belt-driven accessory. A more typical noise from a power-steering pump is a high-pitched whine, not a squeal. Usually, if the steering wheel is stationary, meaning that the steering rack is not "asking" for assistance from the high-pressure fluid from the pump, there's little or no noise
The power steering pump is normally connected or driven by the engine with a V-belt. A loose belt can cause squealing as soon as the power steering come under load (e.g. steering left or right while stopped).
Check the tension on the V-belt directly connected to the power steering pump. This may need replacement.
