Question about Philips 201B4099 21 in.CRT Conventional Monitor
Phillips 201B4 turns off 2 seconds after power up
On power up, no led, I can hear the CRT power up. Display on for 1 second, then shuts off. What can I checkj on the power supply?
  • 60 Answers
First you need to check if your coputer it is powered on. try your monitor to other computer and other monitor to your computer to see where is the problem
Posted on Dec 10, 2008
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
No display
Power drain would be a better solution in this case. 1.first shut down the comp 2.unplug the charger 3. remove the battery and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jan 12, 2010 | HP 2133 Notebook
When i turn my CRT on, after a few seconds my screen goes blank, then displays again, while this thing is happening, i can hear something switching... power led is on(green)... even when the display goes...
It sounds to me that the monitors power supply is dying. I would replace it with a different monitor as soon as possible. I would consider this a dangerous situation, and a possible fire hazard.
Thanks for using FixYa,
Hope this helps,
Eric
Dec 11, 2008 | ZT Group CISNET A7050 PC Desktop
19" Topsync CRT display is flickering
the motiter to pc cable is problem yaar you change it the problem is solved
Dec 06, 2008 | ZT Group CISNET A7050 PC Desktop
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
Vs-50609
Good Day, checho3435;
Look for fluid on the PCB's or check these items:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source). Good Luck, big IRISH>
Jul 30, 2008 | Mitsubishi WS-55807 TV
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Philips 201B4099 21 in.CRT Conventional Monitor Logo
131 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
