Question about Gateway 3018GZ Notebook
3520 Laptop stops 5 secs after starting.
Yesterday eveything appeared normal. I walked away from the laptop and when I came back the screen was black. I used the power button to turn off, then restarted. Restart appeared normal but after a few minutes (I was back into a microsoft word document) it went black again. Each time I have tried to restart the time from the begin to the black screen has reduced. I am now at about 5 secs and seems to be steady at that. I have just enough time to see the menu for safe mode but not enough to make a selection before blackness. When blackness comes the small indicator for the hard drive is no longer flickering but out. This email is from my desk at work but I have my laptop with me.
  • tony308 Dec 09, 2008
    How can I access and check the cooling fan?
    I braved the dangers of taking of a cover and lo and behold the fan is only kind of shuddering and not running. I will replace and get back with you.
  • Gateway Master
  • 19,396 Answers
It looks like an overheating problem, check if the CPU fan is rtunning, if it is not running replace it.
Posted on Dec 09, 2008
  • Ginko
    Ginko Dec 09, 2008
    the problem can be overheating becauise of a defective cooling fan, or a system fault with system noit starting and computer shutting down after few seconds.
    The fact that time is reducing, may let think that this is overheating.
    To find out if it is overheating , enter in BIOS menu, by clicking the bios button at startup (usually you hit one of the function keys on startup. must be written on the screen at startup)
    If the Bios screen stays on for over 30 minutes (in bios setting mode the CPU overheats much slower), then it is not overheating.
    If the computer shuts down in BIOS screen , then there must be something wrong on the cooling system, probably one of the internal fans must be replaced.
  • Ginko
    Ginko Dec 09, 2008
    To access the fan you need to take apart the computer.
    If the system starts you can use a software to control the fan
    SpeedFan - Access temperature sensor in your computer
    The problem is that your computer is not even starting.
    Check if the computer stays on when you do not start the system, entering in bios mode, or using a bootable install disk.
    If computer stays on, reinstall the system, if it doesn't, have the fan checked.
Toshiba Satellite L505D-S5983 black screen
Hold the power button down until the unit shuts off, wait 10 seconds then turn it on again.
Upon restarting, make sure to choose Start Normally if the startup failure menu comes up.
Apr 13, 2014 | Toshiba Satellite Computers & Internet
Black screen
Start the laptop in safe mode and run System Restore
After that I will suggest you to update your drivers just go the site of your Laptop manufacture. Once there enter the model number OR service tag of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop
If this didn't help you then it seems that there is registry problem with your OS. so simply get the Intel software partner Reginout to fix all the registry issues which are causing black screen.
Jun 19, 2013 | Dell Latitude E4300 PC Notebook
Black screen before login
1- Try to start your laptop in safe mode, normally Pressing F8 key when windows starts up
2- After that Update drivers for your hardware from the site of your Laptop manufacture. Once there enter the model number OR service tag of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop. Most black screen are hardware or driver related so updated drivers could fix the cause of the STOP error.
3- Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen
4- If this didn't help you then simply get the Intel software partner Reginout to fix all the errors which causing Black screen
Sudden black screen during use, won't power down, won't power up sometimes.
If you haven't installed or not aware of any application installed recently on your laptop then--
your OS has been loaded with lots of unwanted or overloaded stuff;
1) First try to clean all junk files
2) Clean Cache
3) Free Up some space from your OS drive (most system it is C:\)
4) Uninstall unwanted programs
5) look into task-manager for his program usage
6) Check your Antivirus software
Apr 22, 2017 | Acer Aspire 5515-5187 Notebook
About a year ago out of the blue, my laptop screen started turning off but the computer was still running. It has Windows Vista and Ubuntu. The problem was that the screen would start up normally and then...
it sounds like a mother board or graphic card problem
get a proper diagnosis from a computer repair shop but technology is improving every day and laptops are getting lighter and faster so after getting the diagnosis and quote a replacement may be the option to consider
Mar 13, 2017 | Everex StepNote SA2053T Notebook
Yesterday, I left my computer to talk with a
I would need some more information to completely help you. When you say you walk away and the pc shuts down and starts back up, does it close down (reboot) or does it go into screen saver / sleep mode? What button did you push for the power button light to blink? Have you put the PC into sleep / hibernation mode by pressing the power button once.
Apr 07, 2009 | Gateway MX3225 Notebook
This is for Ginko: Last Tuesday I described a problem with my Gateway 3520 going to "black screen" 5 secs after turn on. You analyzed a cooling fan problem. I removed the cover etc. and found that the fan...
see if the connectors are broken or working
the wires/board integrations are intact or not
see if it works
if not post any other data adn i will solve it
Dec 14, 2008 | Computers & Internet
Gateway 3018GZ Notebook Logo
21 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
