Is it the smaller water hose from the heater core? Coming from the firewall behind the engine? The metal fitting on the water pump will have to be replaced. Some are threaded and screw in. Others are press fitted, If a shop can get to the fitting where it is, they might fix it easily. Otherwise, you may need to have the pump removed, and a new fitting installed, or hey, a good time to replace the pump.
Good luck.
Does not comfrom heater core nor from my water pump it comes from looking down at engine the right or water pump from a metal/steel bar or cover something right off engine.Hose broke off from this metal piece that stemed from this bracket
Does not come from heater core nor from my water pump it comes from looking down at engine the right of the water pump from a metal/steel bar or cover. something right off engine.Hose broke off from this metal piece that stemed from this bracket
I have a 2000 Dodge Caravan 3.3 L that requires what sounds like a similar repair. Using phosphorescent die I traced the leak to a gasket between the engine block and what appears to be a housing for the water pump, though it is much larger than the pump and odd shaped. The water pump isn't leaking as far as I can tell. Can anyone explain this one to me? I want to do this repair myself but have don't know if I'm getting in deep with this one.
SOURCE: 2004 Dodge Grand Caravan water pump
no it only calls for like .8 of an hour to chang it. it is very easy to change
SOURCE: Dodge 2000 minivan,water pump leaking
Make sure it's cool, pop the radiator cap, Remove the shield on the passenger side between the tire and front of engine. Relieve the tension on the serp belt,draw yourself a diagram of the pulleys and belt routing in case the sticker is gone on the strut tower, remove the serp belt. Take the bolts out of the pulley on the front of the water pump (3). Remove the lower radiator hose at the front cover to drain the coolant. Remove the 6 mm bolts holding the water pump to the front cover housing. tap on the pump with a rubber hammer. Install a new gasket on the new pump, and a weap hole diverter in the pump (round black about hte size of a quarter), use old one if there's no new one. Install pupm and tighten bolts snug with a 1/4" ratchet. Install pulley and 3 bolts. Install belt, top off radiator with 50/50 mix green coolant. start engine and run to operating temperature,make sure the belt is seated in all of the pulleys and is running true, radiator fans should come on. Shut engine down and let cool overnight. Check level in radiator and overflow bottle, top off as necessary.
SOURCE: Dodge 2005 Grand Caravan water Pump replacement
JUST COMPLETED THIS JOB TODAY. MAKE SURE THE ENGINE HAS COOLED DOWN . IT TOOK APPROX 2 1/2 HRS. DISCONNECT THE NEGATIVE POST ON THE BATTERY. JACK UP PASSENGER SIDE FRONT AND SUPPORT ON JACK STANDS. REMOVE PASS. FROUNT TIRE. DRAIN RADIATOR INTO CONTAINER FOR PROPER DISPOSAL OR REUSE. USING FLOOR JACK PROVIDE SLIGHT TENSION ON OIL PAN WITH A SHORT 2 X 4 WOOD PIECE TO PROTECT OIL PAN. LOOSEN 3 ENGINE MOUNT BOLTS ON PASS. SIDE OF ENGINE COMPARTMENT. ALLOW APPROX 1" BETWEEN SHOULDER OF BOLTS AND MOUNT. LOWER ENGINE UNTILL BOLTS ARE SET ONTO MOUNT. REMOVE ENGINE SPLASH SHIELD INSIDE WHEEL WELL OF REMOVED TIRE. LOCATE WATER PUMP AND LOOSEN 3 PULLEY MOUNTING BOLTS (THIS IS WHILE BELT IS ON PULLEY) REMOVE SURPENTINE BELT AND CONTINUE TO FULLY REMOVE THE PUMP PULLEY. IT WONT COME OUT AS THE PUMP & PULLEY HAVE TO COME OUT TOGEATHER. REMOVE 5 WATER PUMP BOLTS AND CAREFULLY WORK WATER PUMP OUT BETWEEN THE ENGINE AND VEHICLE FRAME. CLEAN ALL MATING/GASKET SURFACES AND BOLTS. USING A SMALL AMOUNT OF TACKY SEALENT TO INSURE THE NEW WATER PUMP SEAL STAYS IN PLACE, THE INSTALL IS PRITTY MUCH THE REVERSAL OF REMOVAL.
GOOD LUCK, REMEMBER TO TIGHTEN ALL BOLTS TO MFR SPECS AND BLEED THE AIR OUT OF THE COOLANT AS REQUIRED.
SOURCE: 2001 Grand Caravan no heat and occasional over heating.
depends on the engine....a 2.4 requires the removal of the timing belt......on a 3.3 /3.8 the water pump is on the passenger side close to the fire wall.look for an orange or green coored residue in the vacinity of the pump....i would bet its leaking
SOURCE: Water Pump leakes from steel tube.
when installing new o-ring on tube, lubricate o-ring and stick it in water pump. Then pull pressure back on tube and then tighten hold down clamp. problem solved
