Question about Epson Stylus Photo 1290 InkJet Printer
Epson stylus photo 1290 'bk ink cartridge not installed properly'
Black cartridge was empty. I followed the software procedure to change it (open the print cover, than click on 'ok'; take off the empty cartridge, than click on 'ok', put the new cartridge and press the clip till hear 'click'. Done. at this point the software doesn't shows the OK button, it remains gray) so I closed the window stopping the procedure. Now the printer put out this message " the black ink cartridge doesn't installed properly".
what should I do? i tried more times to do againg the procedure. but every time at the same point the software doesn't shows the OK button.
thank you
  • 4 Answers
Ameter:
Remove the black ink cartridge.
Check the place where the new cartridge should go. Check for a round small piece like a bushing or a little piece of pipe, stuck at the ink entrance of the printing head. This is a piece from the old cartridge, that sometimes gets loose and remains in place,and when the new one is placed, it doesnot go down to the right place to make contact with the electric connectors in the printing head.
If nothing solves...reinstall the printer drivers.
Good luck and Merry Christmas
Emiliosan
Posted on Dec 22, 2008
Epson stylus photo 1290 was working fine. replaced ink cartridge with genuine epson cartridge. csrtridge holder jumps and will not print. have repalaced black & colour cartridges. problem continues....
Hi fishbay,
Have you followed the proper way of installing ink cartridge for your printer. You might want to reinstall the cartridges by following the steps on the user manual. You can check page 37 down. You may download the manual here.
Hope this helps.
Thank you for using FixYa.
Sep 14, 2011 | Epson Office Equipment & Supplies
Out of ink message but just put new cartridge in
fix your cartridge properly...maybe it is not in plce...refer for manual so that you have put it in right place...
try to rest your printer if you know how...
Feb 06, 2010 | Epson Stylus Photo 1290 InkJet Printer
Red light on after changing ink
Perform the following procedure:
n Press the ink cartridge replacement button until the print head has moved to the change cartridge position
n Lift the lid that holds the cartridge (do NOT remove cartridge) and press down immediately. Then press the ink cartridge replacement button and allow the cartridge to charge the print head. Do NOT switch the printer off until the printer has finished charging.
Does this solve the problem?
Yes: Solved
No: Go to Checkpoint 2
2. If you have printed between 100 and 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Go to Checkpoint 3
3. If you have printed more than 300 pages, and it is your first ink cartridge, or it has been installed for at least 6 months, replace the ink cartridge.
Yes: Solved
No: Further help required
If red light again you must download resetter software from internet to reset your printer.
Aug 21, 2009 | Epson Stylus Photo 1290 InkJet Printer
My epson stylus photo 1290 sounds like its printing but theres no ink on the paper, there is ink in the cartridges
HAVE YOU TRYED WIPEING OFF THE PRINTER HEAD WITH A DAMP CLOTH TO CLEAN OFF ANY DRY INK OFF THE HEAD ?
Apr 14, 2009 | Epson Stylus Photo 1290 InkJet Printer
Epson 1290 - I just want to print in black and white
Unfortunately, Epson printers demand that both black and colour cartridges are OK before the printer will work at all. Now, if you are really sure that you only want to print black, the most cost-effective solution for you is to buy an Epson Chip resetter on E-Bay. This will reset your empty colour cartridge to "full", as far as the printer is concerned. You can then happily continue with your black-only printing.
Feb 01, 2009 | Epson Stylus Photo 1290 InkJet Printer
Epson stylus photo 1290 printing black splodges
Joy:
Once more have the printer to perform the ink nozzles cleaning.
If you are using a ontinuos ink system, place it at the same level than that of the printer.
With the printer in the "replace carrtidge position", put it OFF and by hand, clean the place at which the cartridge rest.
Good luck and merry christmas
emiliosan
Dec 22, 2008 | Epson Stylus Photo 1290 InkJet Printer
Repacing the color inks with black ink on the epson 1290
Well, since you say you'll be using new cartridges you shouldn't have any nozzle problems. About the worst case I can see would be the slight chance of getting too much ink on the paper resulting in wet paper and a stained platten roller. Seems like an interesting experiment over all.
Nozzle problems arise when reusing cartridges. The very thin metal film that is the nozzle assembly gets worn down as the print head moves over paper and after a number of pages printed the little holes that are the nozzles get larger making for fuzzy, wetter than it should be, streaky printing.
Enjoy,
Carl
Dec 14, 2008 | Epson Stylus Photo 1290 InkJet Printer
Ink not empty
You have confused the software in either changing a cartridge when not required or having a chip failure whilst changing multiple cartridges.
Full info on how to get out of this is on my site.
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
Black Won't print on my 1290
I have had these issues before (that's why I never use refill carts anymore: false economy) You'll just have to keep running the clean cycle until it goes through. This may take several tries, and will waste tons of ink - hence the false economy of refills!
Feb 12, 2008 | Epson Stylus Photo 1290 InkJet Printer
Stylus Photo 1290
Ratt, Please uninstall all related Epson Stylus Photo 1290 softwares, drivers etc. and also clean registry by using any registry cleaner. After going through all this, restart your OS and reinstall your Stylus Photo 1290. If this doesn't solve your problems, then please try this. Steps: 1) Backup all your important document from where you've install your OS (e.g. c:\) 2) Format the drive where your OS is installed (e.g. c:\) 3) Re-install your OS in fresh. 4) After completing your OS installation, install your printer..... GOOD LUCK !!!
Aug 28, 2007 | Epson Stylus Photo 1290S InkJet Printer
Epson Stylus Photo 1290 InkJet Printer Logo
155 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
