Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
The dishwasher make noise but no water is comming out
  • 750 Answers
Hello
Welcome to Fixya
My name is Huum,
here are a list of the four most common reasons for this problem!
Defective Timer
The timer is a series of switches that controls all machine functions. If one of the contacts in the timer is defective, the machine will lose that function. knowledge of the the use of a vol/tohmmeter is essential to testing the timer as well as the ability to read the timer sequence chart that is supplied with the machine. In most cases this requires a professional technician.
Defective water inlet valve
If there is 110v across the two wires on the water inlet valve when the machine is set to fill, the valve should open and the water should enter into the machine. If the water does not enter, the valve is defective.
Float Switch
The float switch allows water to enter into the machine to a point where the float will rise up off of the switch and disconnect power to the water inlet valve. If the switch is defective or the float is stuck in the up position, the water will not enter into the machine.
Water Source Turned Off
Check to ensure the water source is turned on and water is getting to the water inlet valve.
Thank You For trusting us with your question
Please remember to leave a rating before you leave
Huum
Posted on Dec 15, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I bougt a kenmore 18" dishwasher, the dishwasher
Sounds like the water is either off or a flood safe hose is being used. The valve is energized and water is not flowing in, that is what the humming noise is.
Appliance & Refrigerator Repair
Mar 22, 2011 | Kenmore 18 in. 14432 / 14439 Built-in...
The bosch turns on but does not fill with water and makes a humming noise.
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Here is a tip that will help you to find out why water will not come into the dishwasher... <a href="http://www.fixya.com/support/t4715125-when_water_filling_or_rinsing" target="_blank"></a><br />Dishwasher Trouble No Water entering Dishwasher <a href="http://www.fixya.com/support/t4741705-no_h2o_fill" target="_blank"></a><br /><a href="http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering" target="_blank">http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span>
Aug 26, 2010 | Bosch Dishwashers
No water in dishwasher. When turned on all we hear is a clicking noise.
The problem you have here is the solenoid valve is either not opening or there is no water to the dishwsher. For more help check out this tip.
Heatman101
Feb 03, 2010 | Whirlpool 24 in. DU1055XTP Built-in...
Dishwasher makes grinding noise during wash cycle (after pre-wash). noise persists for 15-20 minutes. It seems as though the inlet valve doesn't open during this phase of the cycle. adding water to the...
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Nov 19, 2009 | KitchenAid Dishwashers
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher makes squeeling noise when filling with water
if the dishwasher is only filling when u hear the noise it could be a bad water valve or if you are lucky it could be the screen in your water valve is dirty, however if it is filling and washing at the same time and you hear a noise like sqeeling it could be your motor, before u replace the motor. check the water valve or screen on valve may be dirty
Sep 16, 2009 | Frigidaire 24 in. GLD2350RC Energy...
Loud clanking noise in dishwasher
Most likely the motor as food caught in the sump would not make a noise you described.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Dishwashers
Dishwasher noise
see the fix at the following link:http://www.fixya.com/support/t204050-ge_adorda_dishwasher Simply zip tie the water tube for the middle spray to the upper basket.......it works!
Sep 02, 2008 | GE Profile PDW8400J Built-in Dishwasher
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
196 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
