Question about Panasonic PT-51G44 51" Rear Projection Television
TV goes off, then On when it wants to.
I have a Panasonic 51", Rear Projection TV that goes off while watching it, then comes on after awhile. I've been told this is due to a faulty Standoff Resistor. Can I replace this myself and how much does the part cost?
  • G.Thomas Martin Feb 26, 2007
    Is this a Standoff resistor?
  • RTTEACHER Dec 18, 2008
    Hi :
    I have the same problem with my Pioneer 51 inch Rear Projection. I'll turn on the power. It briefly shows a green light then it turns red and shuts off the set without any picture ever coming on. Did you ever get a solution ?
    Thank You.
    Genius:
  • Panasonic Master
  • 1,689 Answers
What the person was thinking was that there is a thermo standoff resistor. This will not be the proper fix if there are other faults. The set is probably going off because of more complicated problems. Something is pulling too much current and should be found and properly fixed.
I would suggest to have the set properly serviced. You may be going to some extra trouble for nothing.
I don't have the service manuals for your set to know the exact component layouts and specs.
The following is a simplified example:
I can tell you that the tech should monitor the power supply while the set is running to see the voltage stability. When the set is in the off condition he should then work on verifying the cause of the shut-down. This involves following up along the voltage distributions through the set, and also checking the drive pulses from the scan circuits to see where the probable failure is occuring. Obviously, if there is a voltage shut-down, the scan drives should also be shut down. Then the fault may be a failure in the supply, or something on one of the boards is pulling it down.
Jerry G.
Posted on Apr 12, 2008
Panasonic HDTV from 2001. 51
I had the same problem and fixed it myself with a kit from www.TvRepairKits.com. Works great now.
Jan 09, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Tv wont turn on
how was the pix on your tv befor it shout off if it look like a 3d piix you have bad con.v ic to see f you do open it up and look for two big ic or stk. and look for the power suppy line and unplug it now tv should come if it do come on you have bad con.v stk 392-120or 110
Dec 07, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Tv is to dark contrast it all the way up but its still to dark
trying putting the brightness higher, if it's a rear projection maybe the sunlight coming through the window maybe decreasing the light in the tv.
Sep 14, 2009 | Panasonic PT-51HX40 51" Rear Projection...
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
Power issue
No picture on my Magnavox Big TV RJ8530 S/N 61998120
Aug 06, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Verticle
Please reset to factory settings, if problem still there check the v-sync IC. all the best, kindly rate this solution.
Sep 12, 2007 | Panasonic PT-51G44 51" Rear Projection...
Panasonic PT-51G44 51" Rear Projection Television Logo
44 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
