Question about Sharp AL-1641CS Laser Digital Copier
Right side of paper is faded
We have a brother intellifax 2800 and about 1inch on the right side either ends up faded or missing
  • jdistel Dec 09, 2008
    We have already replaced the toner and the photo conductor
  • jdistel Dec 11, 2008
    Thank you so much for your suggestion i just tried cleaning it with alcohol and the ink is still faded on that one side of the paper. Any other suggestions?
    President:
  • Sharp Master
  • 990 Answers
Remove the cartridge out, you can see a piece glass on the bottom inside the machine. clean up by acohol both side.
Posted on Dec 10, 2008
  • Everett Lin Dec 12, 2008
    change developer, it shoul take care of you.
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
IntelliFax-2820 Plain Paper Laser Fax: We have a Brother intellifax 2820 and it's aking t...
You need to take out the cartridge and slide the tab on the top right from right to left about 20 times
May 16, 2010 | Brother IntelliFax-2820 Laser Fax
Black streaking down one side
You need to open the front cover of the machine and remove the cartridge (drum and toner) On the top right there is a tab that you need to slide from left to right about 20 times, then bring back to home position
Apr 10, 2010 | Brother IntelliFax-4100e Fax
My intellifax is pirnting all faded on the left side but not the right.
have you tried changing the drum imaging unit? It could either be a toner cartridge problem or the drum unit needing replacement. If it's new toner or new drum and this problem started since changing to the new, you may be able to get a replacement at no charge or a refund.
Hope this helps.
Nov 02, 2009 | Brother IntelliFax-4100e Fax
Faded strip down length of paper
CLEAN DRUM UNIT AS PER MANUAL . IF THAT DOSN''T WORK TRY REPLACING DRUM AND/OR TONER
Aug 26, 2009 | Brother Office Equipment & Supplies
Broken paper guide and difficult fax input.
Lets start with the paper feed problem. You need a new paper feed roller to pull the paper in when it should. You need a new seperation pad to prevent multiple pages from being fed at the same time. you will have to look at your machine to determine which parts are needed. here is a link to a company that I do business with. You can find the trays here also.
http://www.precisionroller.com/manufacturers/brother-intellifax-4750e.html
May 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Right side of printed page is faded
pull out your drum unit and look inside machine above where the drum would be. you should see a black assembly that runs left to right with a "****" glass. may need a flashlight. clean that glass off with a clean rag. sometimes toner "scatter" will get on glass and cause this.
let us know,
razors
Mar 26, 2009 | Brother IntelliFAX 4100 Laser Fax
2 inch vertical solid band on right side when making a copy
There is probably dirt or ink on the scanner glass, this would affect both copying and sending faxes.
Here is a link to the manual and a description on page 74 showing how to clean the glass.
http://www.brother.ca/en/products/pdf/manuals/FAX1270-UG.pdf
Jan 21, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Sharp AL-1641CS Laser Digital Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
