Question about Lexmark Office Equipment & Supplies
My printer is ghosting text on initial setup of new ink cartrigde .
    Sergeant:
  • 284 Answers
I dont know what kind of machine you have , but it sounds like a drum problem , you need to replace it.
Posted on Dec 09, 2008
Service engine error 181.514
Service Engine Error 181.2049 Maint failed to prime back pressure
This error most frequently happens during the initial printer setup. Another reason for this error to occur is when using malfunctioning cartridges or cartridges that do not have enough ink to complete the initial setup of the printer.
Inserting a new set of setup cartridges or by using the setup cartridges provided with the machine would resolve this issue. To identify whether you are using the setup cartridges.
If you are already using the new setup cartridges, unplug the power adapter from the back of the printer and re-plug it after five seconds and let the machine attempt a second initial setup.
Jul 26, 2014 | Lexmark OfficeEdge Pro 5500 Inkjet...
Hi, my epson stylus SX210 had ran out of magenta ink, can i still print if the black ink is still full in it?? Naoimh
These printer required replace cartrigde empty to continue printing
You must replace only the cartrigde empty
T0711 Black
T0712 CYAN
T0713 MAGENTA
T0714 YELLOW
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My black cartridge was nearly out of ink and the printing was either ghost text on some lines and on others as if someone had drawn a thin white line thru the text. I have just received a brand new black...
There may be some dust on the contact on the printer, first thing you should do is get a q-tip and clean the contacts carefully to ensure there is no dust or other contaminants on the contacts where the cartridge connects.
Also please could you supply the printers make and model so I can look into this further
Jul 15, 2011 | Office Equipment & Supplies
Printing is blank but I have new ink cartrigde in
The print-head stucks (FIXYA would '****' the preceding word, if I left out the 't') ink from the ink-cartridge, and sprays the ink onto the paper, when the print-head is *NOT* "clogged".
Run a "print-head-cleaning" cycle to "unclog" the print-head.
Apr 27, 2010 | Lexmark Office Equipment & Supplies
We have Epson ink jet printer. It worked fine when we got it last month but now the pictures are really awful - the colors are blurring and running together and there are recurring horizontal streaks...
Maybe the ink cartrigde is running out. Get sure that the cartrigde has enough ink, if it has not then reload it. If it has enough ink, then review that the printhead be clean, (you could clean it by using Isopropyl alcohol), then you can use the tools included in printer software to align or maintain cartrigdes. If this does not fix the problem, then replace the cartrigde.
Apr 20, 2010 | Epson Office Equipment & Supplies
My printer wont accept my coloured ink cartridge
Is it the new original cartrigde colour or not ? If yes, you should ask a guarantee from the seller.
There is a chip inside the cartridge, sometimes it doesn't compatible for the printer software to read the chip.
The printer will keep asking for the new one if there is no ink in the cartridge.
Sep 06, 2009 | Lexmark X2650 All-In-One InkJet Printer
Text is "ghosting" when using card stock
I sort of solved my ghosting problem by selecting print, set up, and then under media type selected thicker paper. This apparently pulls the card stock through at a slower rate which helped tremendously. One of my documents turned out perfect and the other "ghosted" just a little.
Dec 17, 2008 | Brother HL-2070N Laser Printer
Ink cartrigde
Did you remove the protective blue tape from the cartridge bottom, if please clean the cartridge Take a warm, damp paper towel or napkin and gently clean the bottom of the car where ink comes repeat the same process with dry paper towel and try to print , if you still have the problem you can contact lexmark and get the cart replaced with a new one as the cart comes with 6 months warranty.......
Jun 30, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Ink cartridge
we just installed a new ink cartridges..it keep saying install new cartrigde..and so it doesnt print anything at all.
Jun 07, 2008 | Dell 924 All-in-One InkJet Printer
RECOGNITION OF GENUINE CANON INK CARTRIDGE
I posted the original problem. Although the cartridge was genuine I had taken it out and reinserted it as I wasn't sure I had loaded it correctly the first time. Advice from my local retailer was that this was a mistake. Canon PIXMA printers no longer recognise a cartridge once it has been removed. Solution was another new cartridge which I shan't remove until it's empty. When this second cartidge is empty I shall try the first cartridge again as it is still full and unused. It has yet to print anything! Why Canon's helpdesk couldn't help is a mystery. I conclude that Canon's printer management systems are unfriendly to users. They are friendly only to Canon. I hope my experience will help others especially those considering buying a Canon printer. dudbob
Jan 22, 2007 | Canon PIXMA iP1600 Printer
81 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
