Question about Garmin Nuvi 350 Car GPS Receiver
GPS screen no longer lights up
All of a sudden the screen is dim after I got my car washed at dealership. I adjusted it (brightness and contrast) and it doesn't help. I can barely see it.
  • Garmin Master
  • 2,130 Answers
If you can't control it with the controls, then most likely the backlight has died. The entire LCD display will need to be replaced as the backlight is integrated into the LCD display.
- Jim
SHARCNET-USA
Posted on Dec 09, 2008
Construction master pro screen is dim / contrast is low
It uses batteries. So if contrast is dim, it may be time to replace the batteries.
Jan 30, 2014 | Calculated Industries 4065 Construction...
19 inch lcd monitor has dimmed display
tried to adjust in the screen set up menu the brightness and contrast. if can not get with adjustment with very dim display replaced the back light ( cold cathode lamp).
Jul 22, 2012 | Computers & Internet
Hitachi 50V710 The picture is dim, then the bulb went out. I replaced the bulb. all works but the picture is still dim. You can barely see the screen durring the day. And can only use it in a dark room...
I've seen this in two scenarios.
First: The housing of the bulb is dirty (the lens the bulb lights onto) and the internal screen is dirty also.
The second: The bulb is wired reversely of the proper way to wire it. This will light the bulb, but will not light as bright as when it is wired correctly!
Thank you and please rate!
Apr 08, 2011 | Hitachi Televison & Video
Screen is too bright or contrast
You can adjust settings to dim off. Right click on Desktop anywhere and go to Properties / settings / advanced / graphics properties / search for contrast / brightness adjustment.
Mar 23, 2010 | IBM ThinkPad T40 2373 Notebook
Dim display on laptop LCD screen
The part you need is called a CCFL Backlight. Basically, there are lights in the screen that back-light/illuminate the display. Over time it burns out and you are left with a dim and completely dull display. These are a pain to replace and expensive when bought from the manufacturer. But this site has a break down with dis-assembly instructions...if you want to try it.
Mar 10, 2010 | HP OmniBook XE3 Notebook
While using my gps 12, the screen suddenly went dark with just a narrow border of lit screen. batteries good. I can faintly see the pages behind the dark screen.
it turns out I inadvertently adjusted the screen contrast. This is adjusted by holding the left arrow key down after powering up, until the contrast is corrected. If the screen was completely white, holding the right arrow key down after powering up would bring contrast back into balance.
Nov 28, 2009 | Garmin GPS 12 GPS Receiver
My Garmin nuvi 1300 brightness problems
I spoke to Garmin Support about this issue. There are 2 settings for contrast on the nuvi 1300. You need to set the contrast while it is plugged into the vehicle, and also while it is unplugged from the vehicle. The reason for the 2 settings is to save the charge of the battery while it is not plugged into the vehicle or power source.
Sep 14, 2009 | Garmin nuvi 1300 Car GPS Receiver
Outdoor photos are all over exposed and white. Video works fine.
set ur screen first .click one image 1st load on ur pc. see the screen and pc screen then set ur screen brightness and contrast of ur camera
Jun 17, 2009 | Mitsuba DV505 Digital Camera
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Apr 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Cannon NP 6551 (Danka A50) Touch Screen Lost Brightness
SOMEONE TURNED THE CONTRAST BUTTON ON YOUR DISPLAY, YOU JUST NEED TO READJUST BY PRESSING AND TURNING TO DESIRED CONTRAST
Apr 03, 2009 | Canon NP 6551 Black and White Copier
Garmin Nuvi 350 Car GPS Receiver Logo
258 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
