Question about JVC AV-60D501 60" Rear Projection Television
Television Won't Power On
Hello, When I came in from being out on Saturday I pushed the power button on my JVC AV-60D501 Rear Projection Television and it would not power on. The TV had been working all day up till I left when I powered it off. When the power button is pressed the light blinks 3 times and the tv won't come on. Have had no problems until now. Help!
    Top Expert:
  • JVC Master
  • 49,110 Answers
Could be an open internal fuse or power supply failure
Posted on Oct 08, 2017
SOURCE: jvc AV56WP74
Your lamp is probably gone
http://www.projectorking.com/index.asp?PageAction=VIEWPROD&ProdID=693
Posted on Nov 11, 2007
  • 12 Answers
SOURCE: JVC AV-48WP30 48 in. Rear Projection
this is the raw research for this that I have found. It seems like the most likely culprit for this is the stk chips on the convergence board (JVC didn't put nearly enough heat sink compound on should be a small layer all the way across they put on a couple dabs) I hear tale you can check this out by disconnecting the convergence board and turning on the set . only go after the convergence board from the front (behind the speaker grill is another panel, the convergence card is right behind there) there is a sneak circuit which will kick in possibly destroying at least the dvi input and mabie more if the set is powered on with the back removed and you didn't put a jumper in the right place or cover over a hole in the back of the dvi module (supposidly to keep people from hacking movies, like there arn't easier ways to do that if you really wanted to). if that doesnt fix it then I have found several other possibilities but I am now a few hundred miles from the tv that I was working on so havent had a chance to try this out:
No. The CRT driver ICs are prone to shorting and cause this symptom (I just had one with those very symptoms and the green CRT driver IC was shorted). Disconnecting the CRT board does not clear the short on the board. Often then is a small burn mark on the CRT board under the affected IC (but not always). The IC should be a TDA6111Q. Be sure to note the proper position
of the IC as it should face with the letters TOWARD the heat sink!!!!
Larry, Check the CRT driver ICs on each of the CRT boards.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxx
Hi Guys, I don`t see many JVC`s and don`t have the print for this AV48WP30, went out this morning and as customer claimed on phone when you plug set in and turn on it makes a loud thump thump in both speakers 20-30 times then relay clicks, the thump stops, and blue idiot light on front goes dim/bright, dim/bright, have to unplug set to start this same scenario over again. Never develops HV or audio, Will order the service manual today, but would like to know if anyone has seen this before (should say "heard" this before)
I would disconnect each crt board and hv lead one at a time and try. Have seen several bad tubes on that model. The only other problem I have seen on that set is bad convergence amps, however that doesn't cause shutdown.
Perry Bower
Electric Medic
From Tech Repair CD:
JVC\AV48WP74\just went click*click*click when turned on Video drive IC (IC1101) on the red CRT module
shorted. It looked like bad solder on the B+ was the cause
Frequently Used Top Five Repair Parts by symptom code
MODEL NUMBER : AV48WP30 - TV
SYMPTOM CODE : DEAD
TOP FIVE PARTS :
2SC5552-RL
2SC5904-RL
QQH0113-002
STR-F6629B/F7
STK392-110
Above from JVC Web site, also I have seen shorted video drive IC's on the crt boards short and cause this symptom. Try unplugging the 200 volt source to the crt boards and see it the set powers up and stays on. There is a B+ relay which supplies 130 Volts to the horizontal output circuit. Is this relay energizing? I takes about five seconds after the power is turned on for it to energize. If a short is detected on the 130 volt line the blue power lamp on the front will do what you describe and the relay will pulse on and off. (David)
Symptom:
Non-functional Digital Input
Solution:
1. Power off the unit
2. Disconnect the digital input if it is connected
3. Remove the rear cover
4. On the digital input module, using a shorting pin (PC type) or a
jumper, short Pin 1 and Pin 2 of the
SB connector
5. Power on the unit
6. Unplug the unit and remove the shorting pin or the jumper
7. Re-attach the unit’s rear cover
8. Power on the unit, and input the digital source
Posted on Dec 06, 2007
kala
  • 156 Answers
SOURCE: jvc av-48wp55
Replace the IC power STR.s6709 and
Posted on Jan 01, 2008
doin12volt
  • 233 Answers
SOURCE: how can i get jvc projection television, model AV-60D501 diagram?
go to www.servicemanuals.net, you can download the entire service manual there.
Posted on Dec 21, 2008
SOURCE: JVC AV-56WP74
Try unplugging converance board if the tv turns on and has HV replace converance chips
Posted on Apr 25, 2009
TV SHUTS OFF AFTER A FEW MINUTES
Very likely to be a heat issue, the first thing to do would be to clean the ventilation slots in the back.
Feb 28, 2009 | JVC AV-60D501 60" Rear Projection...
JVC AV 60D501 H hold ?
What do you mean jumping, or does the picture look like it is in 3-D?
Aug 10, 2007 | JVC AV-60D501 60" Rear Projection...
How can i get jvc projection television, model AV-60D501 diagram?
Dec 21, 2008 | JVC AV-56WP74 56" Rear Projection...
JVC AV-60D501 will not power on.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Mar 24, 2017 | JVC AV-60D501 60" Rear Projection...
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc television want come on
Reset is done by unplugging the ac cord for a time,then plug
back in...............Please verify model number off sticker on the
                            rear of your tv...let me know.....T.
Oct 22, 2007 | JVC AV-56WP30 56" Rear Projection...
TV will not power on.
Sorry my friend but I had this problem. You definately have to get a repairman out to fix it. The AC voltage regulator has gone bad. Good news is it will cost about 225 bucks to fix which is ALOT better than buying a new TV.
Oct 08, 2007 | JVC AV-60D501 60" Rear Projection...
JVC AV-60D501 I belive it is a 60" full screen projection tv for the last few months the picture has been flickering, Flickering like a VHS with bad tracking. It does this in all imputs, from cable imput...
From what you're describing your focus block is probably failing JVC p/n#129P059050. It's probably also very vibration sensitive. They're about $80.00 dollars and they are also interchangeable with the Mitsubishi focus pack p/n#920p016010. Not a difficult repair - we do about 5-6 a month. Real easy in-home repair. Hope this helps. Bill
Jun 18, 2007 | JVC AV-60D501 60" Rear Projection...
AV-60D501
There is a 5, 9 & 12 volt dc regulator on the chassis that could be causing this. Three legged transistors on small heat sinks. I f you look at the chassis from the rear of tv, is two boards.The one on the left has these reg. transistors. Usually the 9v regulator is bad and a 35ufd @ 50v capacitor near it is bad. From the tuner as ground check the third leg on the regulator for less than 9v dc.
JVC AV-60D501 60" Rear Projection Television Logo
54 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
