Question about Maytag MSD2756G Side by Side Refrigerator
Refrigerator hot and smelling like plastic burning.
I had a Maytag refrigerator for 6 years and working just fined. Recently outside the door of the friger is hot and smelling outside and inside of the refrigerator and friger. If the fan stop running then hot outside the friger, smelling, and compressor humming. When the fan is running then it fine. However the temperature inside of both refrigerator and frezer are fine. Please tell me what to fix this problem. Thanks :)
  • Anonymous Mar 02, 2009
    I have a burning plastic smell coming from my refrigerator, the ice maker is not working, but that stopped working a couple of months ago. Everything else seems to be working fine. The smell is horrible though. please help.
  • kylaroy7 Mar 23, 2009
    OMG!!! I am having the same problem. I had someone come by today and check it but, there were no freon leaks and he couldn't find anything wrong. Just a horrible burning plastic smell. I took everything out of it and put it in the downstairs fridge/freezer. What ever happened with yours? Did it resolve itself? Would love to know your update.
  • 237 Answers
SOURCE: refrigerator won't get cold
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
Posted on Jan 06, 2007
  • 159 Answers
SOURCE: Maytag MFD2561HEQ Bottom Freezer Refrigerator - Freezer working, refrigerator not
Marc of Nc. check to make sure the fan in the freezer is operating when the compressor is on. The only thing the fresh food section gets its cool air from is the freezer. and if the fan is not operating no cold air will get up there. If the fan is running you need to make sure the air duct is not blocked with frost of the evaporator is not iced up. Check that out and get back with me if there still is a problem. Good Luck
Posted on Aug 06, 2007
  • 725 Answers
SOURCE: Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Posted on Aug 18, 2007
  • 236 Answers
SOURCE: Maytag Refrigerator
You don't have enough cold air circulating over into the refrigerator section. This is usually controlled by an adjustable "flap" or door which is hooked to a conrol knob. When you rotate the knob you change the size of the opening which controls the air flow to the refrigerator secton. Also you may may have something blocking this air flow -- --- - like a wrapper from an ice cream bar, etc. Try to find the opening between the freezer and refrigerator sections and look for an obstruction.
Posted on Mar 19, 2008
SOURCE: maytag side by side slowly getting warmer
I have a Maytag msd2422gr side-by-side that has gradually stopped cooling 2 or 3 times.  The solution is cheap and easy: Your unit isn't cooling because the space in which the fan is housed is so full of ice you are getting no cold air circulation. The compressor and everything else is functioning, but the cold that is being produced is blocked by ice. All you need to do is to unplug the unit and entirely unload the freezer. Locate a panel with vent slots on the back wall of the freezer compartment that covers the fan. It is held on by about 4 screws. Lift out the panel and behold the glacier of ice covering the coils. You might want to use a hair dryer or space heater to hasten the melting, but I would warn against trying to chip or break it out because you will probably ruin or puncture an important part. Once all the ice is gone, reassemble and plug it back in. As I recall, it takes a few minutes for the compressor to get going again, but be patient because, if there was ice, that was your problem and if it is now gone, that is your solution. It can't help but work. And from now on, you know to be careful not over-load and block those vent slots in the back of your freezer.  If all else fails go here and get great, free help and every part you could possibly need:
Posted on Jan 19, 2009
Bad fan blower smell and bad smelling and tasting ice cubes from ice cube maker
If unit has a water dispenser, how does water taste? I've run across bell peppers that will emit a bad smell. Keep in mind 95% of all refrigerators circulate air from freezer to refrigerator side and then back. It continues to circulate air so bad produce from refrigerator side will get into freezer side and ice will absorb smell. First, dump all ice. Then line shelves in refrigerator side with newspaper, that absorb smells. You can even try kitty litter in small cups in refrigerator side. Bell peppers gives off that metallic smell and can take some time to get out of unit. Highly unlikely a motor is bad and you've already changed outside water line.
Aug 07, 2015 | Maytag Refrigerators
Frig is very hot on the outside ban that meets the seal
That heat that you feel is part of the design of all refrigerators. Those heaters are there to keep water from condensing on the outside of the cabinet around the freezer door. Just like water condenses on a cup of Ice water. It will do the same on a refrigerator. If those small heaters were not there. The water would cause the paint to rust badly. There are various arrangements of heaters used on Freezers and refrigerators around the doors. Particularly the Freezer door.
As long as the fridge is cooling properly it is fine.
If the fridge fails to get cold, the outside of the cabinet will actually get quite hot.
Hope this helps,
Best, Mark
Dec 28, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hi, Pull the plug and figure out where the burning smell is coming from...something is getting very hot...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Oct 02, 2010 | Maytag MFC2061HES Stainless Steel French...
My Maytag MF12568AES Refrigerator is not cooling. May be I need to reset the computer.
This happens to my Maytag like clockwork every summer. The freezer works fine but the refrigerator stops cooling. The first time this happened, it was the fault of the small plastic DC fan that sends cooling from the freezer compartment to the refrigerator section. A technician replaced the DC plastic with an AC metal fan he guaranteed would last the life of the refrigerator. He blamed govt energy standards as the reason Maytag uses the cheap DC plastic fan in the first place. Problem solved. One year later, same issue with no cooling in the refrigerator, freezer fine. Again today, nearly one year to the day! SOLUTION? Trip the circuit breaker or unplug the refrigerator for a minimum of 5 minutes. A reboot now fixes the problem every time. Who would have thought you'd ever have to REBOOT your refrigerator?
Jun 15, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Refrigerator has an (external) awful smell!
Probable refrigerant leak. It is toxic so don't put off removal.
Jan 16, 2018 | Maytag MTB1891AR Top Freezer Refrigerator
Smelly Maytag
Does it smell like rotten food or what
Jul 11, 2009 | Refrigerators
Smelly fridge`
Can you describe the smell or relate it to something common? Plastic, burned wires, fishy, rotted meat, etc. Is it only when you open the door or can you smell it outside too? Are the temps normal in the freezer and refer sections? When did the smell suddenly get noticed?
Nov 12, 2006 | Samsung RS2630SH Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
1,306 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
