Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Piercing sound while a bit of t.v. watching, we seem to experience a piercing sound in the backroung that sometimes changes pitch when you try and shake the t.v...
    Novelist:
  • 192 Answers
The high pitch squeal you hear is usually caused by a coil vibrating, normally in the horizontal circuit. I've also seen the ferrite bead on the horizontal output transistor do this, but, it is rare. I normally will repair this by finding the coil and "tightening" it. To tighten a coil, technicians use different chemicals, such as, a hot glue gun, rubber silicone or even finger nail polish. I will find the coil that screams by starting with the usual suspects and using a wooden dowel, barely touch the coil and if the pitch of the noise changes, then, thats the coil that needs repaired. If you do not know your way around the inside of a television, I never recommend you do so, since, this procedure must be done with the set turned on and you poke your hands around the inside of the set by the high voltage circuit. Hope this helps your decision.
Posted on Mar 04, 2007
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
My watch stops working, the mechanism works on motion or kinetics. However, even with a bit of a shake it works for a bit then loses time and stops altogether
It may require rather more than a bit of a shake! Some makers say that you have to swing it gently form side to side for 200-300 times to fully wind up the watch.
I bought one some years ago that didn't work well and I had it cleaned, after which it worked perfectly for years.
If giving your watch the shaking I described above it still does not work, try having it cleaned.
Automatic watches thrive on being used but should run for 2-3 days before stopping.
Mar 08, 2011 | Jacques Lemans Classic Automatic...
Gemini CDJ02 - Pitch Control Slider Stuck @ 0% The Pitch Control Slider will pitch down all the way but sometimes it will randomly change pitch and most the time wont pitch-up past 0.1-0%. This happens on...
Your pitch control is faulty or dry. Try spraying wd 40 into the pitch sliding hole form top to bottom. Dont over spray it. Just a bit from top to bottom will do. If issue still persists, then there's some capacitors are weak which controls this pitch.
Jan 15, 2010 | Philips Gemini CDJ-20 Top Loading...
Original circa 1982 Kurzweil Ensemble Grand upright, has been working just fine until today. At first the (grand piano) sound had just become very distorted or seemed to have messed up sustain or echoing....
Given its age, this unit needs a little TLC. Units of that vintage used some capacitors that may have dried out a bit and need to be replaced. There are also op-amp ICs internally that may be defective. I would suggest a visit to a service shop that works on keyboards as not all do.
Keep us posted.
Dan
Dec 08, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
My vizio makes a popping or clicking sound
The sound from my vizio 22" HDTV is not working properly when I attach it to my cable TV.
Sep 29, 2009 | Televison & Video
HIgh pitched sound when accelerating w/ My 2007 Hyundai santa fe
This may sound strange but have someone check out your radio system. Sometimes an antenna wire or wires, when jared loose will make that ear piercing noise. It may not be the problem but it's worth looking into.
Aug 31, 2009 | 2007 Hyundai Santa Fe Limited
Sound wavers (speeds up and slows down)
you need to replace the Pitch controls. I'm presuming it is a sliding pitch control. Use the Red start stop lights that reflect on the rotating wheel. put the pitch in center 0. does one row of the dots on the wheel stay completely still.now just turn it up op down a bit until it starts to move the dots slightly. now watch the dots now while there moving. Do they fluctuate they should be smoothe. do this on both decks to find out which one is fluctuating.
Jul 10, 2009 | Philips gemini XL-500 II Turntable
High pitched ear piercing tone when turned on.
sounds like you have a crossed wire somewhere
May 19, 2009 | Car Audio & Video
Rca hd52w59
ok does the set show a picture durring this whinning
i have ran into this problems .. sometimes it has to do with a coil that is oscillating...ll037 or ll029...the fix for this is simple if it is the problem. dampen the coil with silicon.
Mar 26, 2008 | RCA HD52W59 HDTV Projection Television
Piercing Sound and Freeing of PC
I sugest that you check your bios settings first before going any further and make sure you have updated drivers.
Nov 21, 2007 | ASUS M2N-MX Motherboard
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
69 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
