Question about Dell Dimension 8200 PC Desktop
My Dell will not start up. I get to the Dell screen and then get an message that says: Primary hard disk drive 0 not found. Do I need a new Hard drive?
  • phxfirebard Jan 02, 2009
    put a new hard drive
    but still no work
    Problem Solver:
  • 9 Answers
If you any experience getting into the system bios you can check to see if the system still sees the hard drive by pressing the F2 or DEL key on startup. This screen shows a system bios with hard drives present. ( http://techgage.com/reviews/asus/barebone_690/pundit_21_thumb.jpg ). If it does not show up it could be that it came unplugged however unlikely. But you could try opening the system and checking to make sure the hard drive is still plugged in. Some manufactures tend to plug devices in fairly loosely. It may look something like this (http://www.laray.com/build/drive5.jpg) or like this (http://lib.store.yahoo.net/lib/cooldrives/ide-drive-to-sata-adapter-plug-image-2.jpg)
If all this seems too much, you could take the PC to a repair shop and have them check to see if your harddrive is still properly installed. If it is still installed but keeps giving that error then you probably need a new hard drive.
Posted on Dec 09, 2008
    Scholar:
  • 55 Answers
Try going to the BIOS page by pressing F2 on the Dell screen. Check if the hard drive is detected. Normally, you'll know if it's detected because it will show the HDD space. If it's not detected it would say "Unknown".
You can also try reseating the cables of your hard drive. Open the tower, unplug the cables connected to your hard drive. Plug it back in. Reboot the system. If you get the same message, then your hard drive needs to be replaced.
Would appreciate if you rate this if this would help.
Thanks, ArnWuLF.
3 Suggested Answers
flexydove
  • 80 Answers
SOURCE: Dell Dimension 8250
Yes you need a new hard drive
  • 164 Answers
SOURCE: Dell: Primary hard drive 0 not found Primary
Sorry, but this isn't a good sign. Drive 0 is most likely your main hard drive, and only if you have a second one would you computer ever find anything on Drive 1.
I would check the connections inside from the motherboard to the hard drive, as well as from the power supply to the hard drive.
Here's the manual: http://support.dell.com/support/edocs/systems/opgx60/en/ug/sffabout.htm#1103481
Also, if you boot your computer to the Dell copy of Windows, go through the motions of reinstalling Windows and you probably won't be able to detect any drive to install it on.
You'll most likely need to replace the hard drive altogether. Sorry!
Hope this was helpful for you (even though it was bad news)! If so, please give a rating!
Posted on Mar 09, 2010
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Primary hard disk drive 0 not found no bootable
Your hard disk is disconnected, or not configured correctly in the CMOS. Go to the BIOS and be sure that the computer recognizes the hard disk. If doesnt happens, check the connectors, and if it doesnt fix your problem, you need a new hard drive.
Jul 18, 2009 | Dell Latitude C640 Notebook
Dell optiplex gx110 device detection problem
I'm guessing that the computer is not booting at all. This is saying that it cannot find any hard drive to talk to. Drives are labeled in the computer code with numbers starting at 0. There are up to 2 drives on an IDE ribbon cable, the Primary, and the "slave" or secondary. So, possibilities are that your hard drive died, the power connector to it came loose, or the power supply itself is having an issue with that connection that is attached to the hard drive.
Jun 11, 2009 | Dell OPTIPLEX GX110/200 PIII-866MHz 256MB...
Dell dimension 2400 diskette drive 0 seek failure
Check your BIOS setting to see if it detects the hard drive (Primary disk 0). If it can't detect the hard drive then the hard drive maybe faulty. Open the case unpluge the IDE cable from the hard drive and reconnect it again, also unplug the IDE cable at the motherboard and reconnect it again including the power connector on the hard drive.
There maybe an option to test the hard drive in the BIOS, if so use it to test the hard drive.
If the hard drive is faulty, you need to replace it and install Windows, the various device drivers and your programs to get a functioning computer again.
You might consider buying a new computer (it will be faster & better than the old Dell) and you have your new monitor to go with it.
May 21, 2009 | Dell Dimension 2400 PC Desktop
Dell inspiron 5150 primary hard drive disk 0 not found
You may find that either the cable is not connected properly or is faulty, or the worse case the mother board has problems (driver, chips, breakages)
May even be a power supply problem, as the power supply has many output points and different voltages that the HDD power out may have blown. If it has then the rest of the system will appear to be ok.
So first off, check the cables connections on the motherboard, and look for any breaks in the cables, and if you have a power meter of some sort check the power connection, or plug in another power connector, the ones with the same end are generally the same power outputs. The ribbon cable for the HDD should have 2 sockets for HDDs and you must connect your HDD to the end one.
May 14, 2009 | Dell (U0614) for Inspiron 5150 60 GB Hard...
Dell 8250 Hard drive 0 not found after move from US to UK
IT sounds like the hard drive went bad, especially with the clicking noise. If you want to keep the system, you will need to buy a new drive (relatively cheap) from tigerdirect or newegg and istall it. NOt sure if dell still send out recovery cds with their systems but if you have one just insert the cd after you install the new drive and follow the prompts. If you do not have one contact dell support and they should beable to send you one
Jan 21, 2009 | Computers & Internet
Dell Dimension 8250
Dec 09, 2008 | Dell Dimension 8200 PC Desktop
Laptop won't boot..
try new hard drive 1st ok
Jan 30, 2008 | Dell Inspiron 8500 Notebook
Dell Dimension 8200 PC Desktop Logo
139 people viewed this question
Alun Cox
