Question about Dell 962 Photo All-In-One InkJet Printer
Dell Photo All in one 924 - shows carriage jam but paer is clear
Solution sought
  • 1,049 Answers
The all-in-one printers are notorious for getting small pieces of paper lodged in the gear assemblies both in the back behind the paper pickup roller and in front under the print head. Dust also can collect causing false errors. I would first blow the thing out thoroughly with a can of compressed air because honestly any other solution is probably going to cause you more time, money, and trouble then just replacing it the printer; especially if the Dell printer is under warranty.
But for the sake of diagnosing the issue specifically...Look for damage in and around the print head, especially the bundle of wires attaching to the back of the print head. If they are damaged it will generate a carriage jam. Also, listen to the head when it tries to move, if it clicks or pops or if when you restart the printer it fails to move across and back to align itself, your drive gear on the print head is stripped or the assembly itself is not functioning.
If it moves and aligns itself but then gives a carriage jam anyway, it's obviously not jammed because it moved. That means that the control board or system board may be damaged and these are VERY difficult to replace without disassembling the whole printer.
Posted on Dec 09, 2008
I have a carriage jam, how do i clear it on my Dell Photo A10 928
This seems to be fault in the carriage mechanism. Start this work only if you are mechanically able with the right tools.Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the carriage can be turned manually so that you will be able to see it move freely while studying if there is any obstruction.
Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Jul 12, 2011 | Dell 924 All-in-One InkJet Printer
Dell 942 carrier jam loud banging
you going to have to replace the carriage ASSY. That sound means the carriage is offline and it needs repair or you got something blocking or jammed in the printer so good that its doing this.
Diag : bad carriage or severe carriage jam
prog: Repair/clear jame if any or new printer
Thanks please do click the accept button for my efforts.
Apr 07, 2010 | Dell 924 All-in-One InkJet Printer
Can't install cartridge - carriage won't move to center?
924 dell pinter keeps paper jamming makes noise like it is printing and grating noise
Jan 31, 2010 | Dell 924 All-in-One InkJet Printer
Dell photo 924 is completely unresponsive. Power
Pitch it. There does not appear to be a firmware update. That would be the only thing that would have a chance of fixing this. Otherwise, the controller board is shot. The cost of repair is more than the printer, buy a new one.
Oct 26, 2009 | Dell 924 All-in-One InkJet Printer
Where do you insert the ink cartridges for the dell 924?
You lift the Top cover, and wait for the ink carriage to take place in the middle of the rail. Lift the plastic lid holding the old cartridge in place. Then snap the old ink cartridges pulling toward yourself and then up. Put new cartridges in reverse order.
Owner's Manual
Dell Photo All-in-One Printer 924
Sep 16, 2009 | Dell 924 All-in-One InkJet Printer
Narrow strip came out from my printer (dell all-in-one photo 924
It goes through the ink cartrige holders and hooks onto the frame. It's called an encoder strip.
Feb 16, 2009 | Dell 924 All-in-One InkJet Printer
PAPER JAM !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Since when the printer not picking up paper from tray or sheet feeder.
Check if the Cover are firmly closed, also look out for any piece of paper jammed the printer.
If it is ok, then check to move the carriage of cartridge/roller and clean it out if you can.
The spring of tray attached on both side may be need to check.
Let me know if I can assist you further.
Oct 01, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924
**HW support: 877-459-7298 and you must have the Express Service Code of your printer or any Dell product you're calling in so that they can route you to the right department.** Usually, if you're having paper jams, it could be a mechanical problem with the printer. Try these: - turn off the printer. unplug the power adapter for 1-2 minutes - lift the printer upside down and shake it sideways (strange huh?... usually, this helps because it can re-align those things that may not be aligned right inside the printer) - then, adjust the paper guides and use about 10-15 pieces of paper. try using the printer. if it's still the same... it really is the printer. - if it's still under warranty, Dell can replace it. This information is from Dell, try it it can't hurt.
Mar 09, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell 924
Check the paper track- just in case a fragment has ben elft behind. A suck out with a vacuum may be a good ides to be sure. Then close it down unplug the mains supply. Leave a couple hours- then see what happens If still introuble take a look on here
May 31, 2007 | Dell 924 All-in-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
307 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
