Question about Nintendo Wii Console
I have the system won't read disc error
I have tried multiple games and cleaned them before putting them in and it still is coming up with this error. Is there a way to clean the system with a DVD cleaner or not?
  • Anonymous Dec 09, 2008
    same situation and it doesn't matter if the disks are clean, new, or used.....what's up and how to we solve it?
  • 32 Answers
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Posted on Mar 04, 2009
  • 20 Answers
This is a hardware failure. Sending it Nintendo is the only option. Unless you think you have the skills to repair it yourself. Here is the link to Nintendo
http://www.nintendo.com/consumer/repair/repair_options.jsp
if you want to repair it yourself. You will need a new wii dvd drive. Any version works.
Posted on Dec 10, 2008
Reads no disc or see instruction manual every time you turn it on
  1. Some games may need to be cleaned. Clean each disc with a soft, slightly damp cotton cloth (use water only). Clean them from center towards the edges; do not use a circular motion. DO NOT use paper. Once they are cleaned, dry the disc using a dry portion of the cloth and wiping in the same style as you did to clean the discs. After all of the water is gone, let the discs sit for at least two minutes to completely dry before inserting any of them into the Nintendo GameCube.
  2. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
  3. Ensure the games are being loaded properly. With the power turned off on the system, replace a Game Disc (printed side up) in the system, press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen. Try this with a few of your games.
If Troubleshooting doesn't fix the problem, and it is happening with all your games, then your system will need repair. Check out our convenient repair options.
  • No Game Disc:
    This error can occur when the Game Disc has been removed while the system is on and then the Disc Cover is closed. Follow these troubleshooting steps:
    1. Ensure the game is inserted correctly. With the power turned off on the system, replace the Game Disc in the system, printed side up. Press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
    2. Determine if this happens with more than one game by inserting a different game into the system.
    If the error occurs with all games, follow the Multiple Game Disc troubleshooting.
    If the error occurs with only one game, follow the individual game disc troubleshooting.
  • Troubleshooting - Multiple Discs
  • Jan 09, 2011 | Nintendo GameCube Console
    My game cube will read disks but after a while it skips and says disk read error
    The Disc could not be read:
    Dec 08, 2010 | Nintendo GameCube Console
    The disc in the game cube does not turn. the error say, game disc cannot be read.
    Single Disc
    The following steps are for problems with a single Game Disc or if you only own one game. If more than one game is experiencing problems, please link here.
    Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your Game Disc. Please check our game play help for assistance.
    1. Ensure the disc is free of dust and contamination by cleaning it. Clean the disc with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
    2. Dry the disc, using a dry portion of the cloth and wiping in the same style as you did in step 1. After all of the water is gone, let the disc sit for at least two minutes to completely dry before inserting it into the Nintendo GameCube.
    3. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory
    Nov 28, 2010 | Nintendo GameCube Console
    Disc wont read
    Single Disc
    3. Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
    4. Check for specific game issues. Some games may have known issues or game play elements that appear as problems.
    5. Ensure the game is being loaded properly. With the power turned off on the system, replace the Game Disc (label side up) in the system, press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
    6. Look for obvious physical damage to the disc. Remove the Game Disc and check the non-labeled side for cracks, scratches, smudges, or dirt. The Nintendo GameCube has extensive error correction capabilities and minor scratches or contamination should not cause issues in most cases. However, it is important to determine if disc damage is causing the problem.
      • If the disc is cracked
        Review our disc replacement policy to determine how to get your game replaced.
      • If it's dirty, scratched, or shows no obvious damage
        1. You may try cleaning the disc again with a soft, slightly damp cotton cloth (use water only). Clean the disc from center towards the edges; do not use a circular motion. DO NOT use paper.
        2. Make sure the game is dry, then re-insert it and see if the error occurs again.
        3. If the game had been working normally, shows signs of physical damage, and now displays errors or lockups in areas it previously didn't, the problem is likely to be the damage to the disc. Use the disc replacement policy to determine how to get your game replaced.
        4. If the game never worked or you are discovering errors in areas you have entered for the first time, it is possible that the problem could be with the system or the disc. (The system may still be the problem even if the disc shows some signs of damage.)
    7. If possible, try the disc in another Nintendo GameCube. If the disc works properly in another system, the problem is with your Nintendo GameCube. Please check out our system repair options. If the game still does not work in another system, it is likely a problem with the Game Disc. Please review our disc replacement policy to determine how to get your game replaced.
    If you are not able to try the game in another system and the other troubleshooting steps haven't narrowed the problem down, it is impossible to determine for certain whether the problem is the Nintendo GameCube or Game Disc. Please contact Nintendo's Consumer Service Department at 1-800-255-3700 for assistance.
    Aug 06, 2010 | Nintendo GameCube Console
    Disc Doesn't Spin. 'No Disc' Appears.
    Try cleaning the laser with a Q-tip.
    Apr 11, 2010 | Nintendo GameCube Console
    The gamecube turns on but won't read the disk.
    Mar 08, 2010 | Nintendo GameCube Console
    Disk read error
    Jul 03, 2009 | Nintendo GameCube Console
    Does Not Play
    Dvd drive needs to be serviced or replaced.
    Jan 28, 2009 | Microsoft Xbox 360 Console
    Wii will not read disc
    If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
    Jan 01, 2009 | Nintendo Wii Console
    Game will not read disc. Starts and then says error
    Dec 28, 2008 | Nintendo Wii Console
    Nintendo Wii Console Logo
    724 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Julian Wainwright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
