Dvi cable does not work on my medion 19
Dvi cable does not work on my 19'' medion lcd monitor.it used to work,but now when i turn my pc on the screen stays black.can you help
  • 558 Answers
Sounds like the computer is thinking you are output on the rgb cable an you connect a rgb to the computer also and then see if you can switch them in the display settings.
Posted on Dec 09, 2008
  • IMTUSEXY247 Dec 13, 2011
    hello i just bought a 19" Soyo monitor but i think i got the wrong cord. When i connect all the cords RGB appears blinking on and off the screen and the screen stays black. The cord i purchased says male also it says video. I dont know what im doing wrong some advise would be greatly appreciated.
What connections are required
Make sure the monitor works on a friend's PC using the DVI... let's not go backward to VGA when DVI is available on both the PC and monitor. If the monitor works, install the driver and reboot. It should work for you too.
Jun 19, 2014 | Gateway HD1900 19" Monitor
Can i hook my 47inch tv to the monitor
You can't hook you TV to the monitor itself, rather the computer.
If your PC has a wide white connector (DVI) that is supplying signal to the monitor, you could use a DVI to HDMI adapter cable to connect your PC to your TV. This is also possible if your PC uses a small blue connector with 15 pin holes (VGA) by using a VGA cable to connect your PC to your TV.
Mar 17, 2011 | Acer AL1916W 19" LCD Monitor
I have a 20" HF205
You only need to use the DVI cable. If your computer has a spot for one dvi and one vga, you will be fine. Hope that answers your question.
Mar 06, 2011 | Hannspree 19" Widescreen LCD Flat Panel...
Samsung syncmaster 930b 19inch: blinking green light on startup screen does not respond turn off or on after a random time period it usually works once screen goes from black to windows it stays...
<P>If you try new cable, try with another PC and still have the same problem, then you need to inspect the inside for bad caps first just like all the SAMSUNG as shown.</P><P style="tab-stops: center 3.25in left 255.75pt"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://s807.photobucket.com/home/budm/allalbums"><FONT color=#800080>http://s807.photobucket.com/home/budm/allalbums</FONT></A><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</A><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <A href="http://lcdalternatives.auctivacommerce.com/Viewsonic-C196320.aspx"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>http://lcdalternatives.auctivacommerce.com/</A><SPAN style="mso-spacerun: yes">&nbsp; </SPAN>he can make you a set of caps for you.<o:p></o:p></SPAN></P><P>&nbsp;</P>
Aug 25, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Driver for windowsXp
for what model? also usually you dont need a driver for a monitor or LCD, you might need a driver for your graphics card. And still We'd need to know the model and or the model and name or your pc to help you further.
Sep 09, 2009 | Maxdata 101905 19 inch LCD Monitor
Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
Jul 21, 2009 | LG 22" FLATRON LCD Monitor
Blank Screen using HDMI-DVI cable for PS3
Sounds like your LCD monitor isnt HD compatible.
Mar 17, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
Put an adaptor on my cable and the monitor screen goes blank
Hi Kathy,
Nothing you can do, it could be the laptop does not understand Digital Video Interface DVI
What is the laptop make / model?
Mar 13, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Computers & Internet Logo
486 people viewed this question
David Payne
David Payne
