Question about Creative Labs Zen MicroPhoto MP3 Player
Problems not turning on
My creative zen is not turning on. I'm wondering if my battery is dead? This is my second creative zen that i bought. The first one did the same thing and i replaced it, this time i lost my reciet to take it back, sucks for me. Just curious if this has happended to me or somone else has that problem?
Re: Problems not turning on
Mine wouldn't turn on using the power on switch. I suspected a bad switch but when I disassembled the unit I found a cold solder joint on one of the switch terminals.
Using a thermostatically controlled, pencil-type soldering iron and some basic soldering skills. I carefully removed the switch and re-soldered it. Works fine! (If you don't have the right tools and experience, you will damage the board and/or switch.
Posted on Mar 13, 2010
    Uploaded 30 video answers.
    Uploaded 5 video answers.
  • 72 Answers
I have two and found it pays to have a spare battery. The life of the batteries just isn't that great.
Posted on Apr 26, 2008
0 characters
3 Points
My zen won't power off
Some ideas
  1. First, try a reset: Insert a paperclip into the reset hole at the bottom of the Vision
  2. Or, try running off mains power, not battery (in case you have a dead battery)
  3. If you're able to get in to the system, try going into Recovery Mode (see below)
Otherwise, if you have a dead unit, consider returning it to the place of purchase, or contact Creative to get your machine repaired. If the Zen is less than one year old, you should be able to get it repaired under Creative's warranty. For details on how to do this, go to , or you can call +353 1 4333200.
Jul 23, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen stone plus wont turn on
the battery is dead use a car charger it worked on my creative zen stone plus and ipod touch. the car should charge it
Jun 10, 2009 | Creative Labs Zen Stone Plus MP3 Player
Creative Zen should have a reset button on the side, it is a very small hole that you will need a pin to push the button inside, hold the button for about 20 seconds. This should reset the player.
Jan 01, 2009 | Creative Labs Zen Touch MP3 Player
My Creative ZEN 8 GB has Firmware Problems
Try uninstalling Windows Media Player version 11 from your computer before trying to reload the firmware. It works wonders.
Aug 12, 2008 | Creative Labs ZEN SLEEK MP3 Player
Creative zen
Clean first battery contacts recharge again and if is dead, I suggest to try a new charged battery
Mar 22, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen touch dead
same here, have not used mine in about two years. I just found it but the charger was missing, so I bought a wall charger because the usb would not detect it on the computer.the wall charger does not work either. I wonder if the internal battery goes dead after a while. I am thinking of calling customer service, because i do not want to spend money on a new iPod. I will post again after I call for help.
any other posts at all will be helpful.
Nov 03, 2007 | MP3 & Digital Media Players
Creative Labs Nomand Jukebox Zen Xtra
Zen Nomad Xtra - to go to Rescue Mode do the following:
1. Insert a pin into the small hole on the left side of the player
below the volume adjustment switch.
2. Hold down the Play button on the right side of the switch
3. Rescue Mode Menu will appear
4. There are 4 Options available, but best option to fix most
problems is reformat hard drive.
5. Reformat is very fast
6. Turn off and reboot.
7. Problem solved.
Oct 31, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Oct 12, 2007 | Creative Labs ZEN V Plus MP3 Player
Zen Neeon frozen completely
Leave it alone for a while, then try reinstalling the Zen Program, then plug it in, then rest it, then try to switch it on. It worked for me
Jul 27, 2007 | Creative Labs Zen Neeon MP3 Player
Creative Labs Zen MicroPhoto MP3 Player Logo
78 people viewed this question
Top Creative Labs MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a Creative Labs MP3 and Digital Media Player Expert? Answer questions, earn points and help others
