Question about Amana 3.2 cu. ft. Top-Load Washer
Slow hot water fillup
Model Lwa50aw washer, hot water trickels out when filling tub.
hoses are not plugged up.
  • 128 Answers
THIS MIGHT HELP, DONT FORGET TO RATE ME THANKS
Slow-or-no-water-into-the-washer and flooding washer complaints just gotsta be in the top five most frequent appliance complaints I get. Thang about it is that it's just so gawd-awful simple to fix that I'm reluctant to give away the secret to this great cash cow. Yeah, I know, I shouldn't reveal this treasured trade secret that all appliance repair techs swear an oath to defend. What? You say you want me to tell you anydamnway? Well alright then.
Most of the time, your water flow complaints will be about either the cold or the hot water being restricted to near nothing. Sometimes, both the hot and cold water flow are restricted and the water just trickles in no matter where you got the temp control set at. Either way, 90% of the time, the problem is because of sediment built up on the inlet screen of the washer inlet valve.
slow hot water fillup - watervalve.gifHere's a typical two-solenoid inlet valve. This is the most common, although some Whirlpool's use a three solenoid arrangement, but the diagnosis and correction are the same. Most of the time, what happens is that sediment builds up on the inlet screen of the solenoid valve and restricts the water flow into the valve.
Now, here's where you can benefit from my lifetime experience as a certified technical guru. There's something I call the "cute plumber's trick" where the unsuspecting appliance owner calls in one o' them real hairy, stinky plumbers to fix their washer. Well, Buttcrack Bubba correctly takes a look at the inlet valve and figgers he's being reeeel cute by just removing the inlet screen altogether. Most of the time, Buttcrack Bubba does this 'cause he ain't even got a washer valve on his truck so it's the difference between making something off the job 'cause he "fixed" it, or making next to nothing 'cause he didn't have the part and he'd have to come back to do the repair. Buttcrack Bubba's in, what we in the trade call, "the horns of an enema." Yessir, so he goes ahead and removes that screen. The customer don't know any better; heck, all he knows is that water's flowing to his washer again. It's a freakin' miracle!
What happens next, though, is a sad tale to tell. Y'see, after a while, the innards of the valve get so gunked up with sediment that the valve can no longer stop the flow of water when it's supposed to (like, when there's no power on it). You can see here that they's a whole buncha delicate leetle ***** parts in there, da, comrade? Little, itty-***** pieces of dirt and pipe scale can stick that plunger guide wide-ace open. So, water just keeps on flowing into the washer. Meanwhile, you're outside playing with the dog, or changing a poopy diaper, or...whatever. Point is, the washer floods on you and makes one helluva mess in your house. All cause o' that "cute plumber's trick." Now, how smart was that to call in a plumber to do an appliance tech's job?
Other times, problems with no water can be the pressure switch or a burned-out solenoid in the water valve. If there ain't much sediment on the inlet screen of the water valve, you gotsta measure the continuity of the solenoid coil at the terminals. If your meter says there's no ohms in the solenoid coil, that ****** is slap-open and it's gotta be replaced. That's the name o' that tune, Hoss.
Posted on Dec 28, 2008
Washer is filling very slow. Both hot and cold water are just trickeling in
turn off the water supply unscrew the filling pipes and look in the end they usually have a wire gauze filter check for blockages ie limescale
May 30, 2011 | Washing Machines
Very little hot water runs in tub
you either have a problem with the house water supply going to the washer and you can remove the hot water hose from the washer,first shut down the water,stick the end of the hose inside the washer and turn the water supply back on,if the water comes out normal then you have a bad water valve on the back of the washer.call your parts store and give them the full model number off of the washer,open the lid,follow it down to the bottom and right under the bottom of the lid you'll see the model number
Jan 23, 2011 | Kenmore 24032\24036 Top Load Washer
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
Hot water is coming out full strenght through hose but coming real slow into machine. It is a kenmore 110 about 20 years old and still working great except the slow hot water filling the tub.
could be your fill valve plugged up with sediment,remove your hose from the rear of unit and look at the screen inside see if it is plugged up!
Jan 09, 2010 | Washing Machines
I have the LG WM1832cw washer. Something is wrong with the cold water fill. Not the hot water just the cold water fill valve section as it fills VERY VERY SLOW (water trickels in). Hot water fills fast! I...
Is resistance between each terminal of INLET
VALVE ASSEMBLY 0.8~1.2 kω? If not replace it.
Is the inlet valve filter clogged?
Clean the filter.
Verify the voltage of the inlet valve connector is
120 V AC. No voltage? Check electrical connection.
Replace the MAIN PWB ASSEMBLY.
I have an LG training manual which might not be the exact one you need but it gives an idea what to look for.
LG WASHER REPAIR MANUAL
Post your model number at any of these
fine forums for an answer
that will save you big money::
http://appliancejunk.com/forums/index.php?referredby=858
http://forum.appliancepartspros.com/
http://applianceguru.com/
NEW! http://sublimeforum.invisionplus.net/
Nov 10, 2009 | Washing Machines
Water will only trickle to fill ip washer. Is it
Most likely its the inlet hose or hose screen.
If water pressure is standard at all other areas in home secure 4 Hose washers at any lowes ace hardware or garden supply that sells garden hoses. Remove your hoses and place the ends in the basket and turn on the water. If you get a good flow out then look at the water valve inlet behind the washer. If its clean put on the new washers and retry it. Be sure to run the valve wide open a couple of times to flush out any mud or sediment before deciding the inlet is clear. sometimes the old galvanized pipes can be plugged up with rust. If the water is trickeling in and it is suppose to be on then it is not the solonid valve because its trickeling in not flowing. Let me know if this trick works and \please ratem me as high as you can. Thanks for using FIXYA and good luck.
Apr 06, 2009 | Washing Machines
Maytag Washer (approx. 7 years old) has slow stream when filling
Follow the two inlet hoses from the back of your machine. They should each end at a valve (one for hot and one for cold). Make sure that these valves are all the way counter-clockwise and that the hoses are not kinked or pinched.
Jan 19, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Hot water is filling up washer very slow
There is a screen in the valve where the hose hooks on. It could be getting plugged up. turn off the water and pull off the hose to see if it's full of particles. I can sometimes clean it out by putting a bucket under the water inlet and spaying a little water from the hose into the opening. If not you may need a new valve.
Apr 18, 2008 | Kenmore 24032\24036 Top Load Washer
Have model 88675 with slow hot water fill
I once had this problem. The solution was to remove the hot water hose connection to the washer and look at the filter/screen inserted into the end of the hose connection on the washer machine. This screen protects the washer components from foreign particles entering. You may find a badly-clogged screen, so clean it. I have seen a cold water screen clean, while the hot water screen was clogged...something to do with hot water and minerals or iron in water.
Jul 17, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Amana 3.2 cu. ft. Top-Load Washer Logo
267 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
