Question about Dell Dimension 8200 PC Desktop
Dell Dimension 8250
My Dell will not start up. I get to the Dell screen and then get an message that says: Primary hard disk drive 0 not found. Do I need a new Hard drive?
  • Eric Mitchell
    Eric Mitchell May 11, 2010
    Sounds like you need to check you cables inside the computer and check in the bois if it is being seen. First I would look in the bois, to get the press F2 at the begining of boot look around tell you and tell me what you see
  • Anonymous Mar 21, 2014
    I am getting NTLDR is missing message on start up.
  • 80 Answers
Yes you need a new hard drive
Posted on Dec 09, 2008
  • PETER
    PETER Oct 29, 2013
    I HAVE REPLACED WITH NEW WORKING HDD BUT STILL NOT DETECTING AMONG DRIVES, WHAT MORE OPTIONS DO YOU THINK MIGHT BE OBSTRUCTING ITS DISPLAY?
When I start up my Dell Dimension 8250 (Windows
Sounds like the machine got stuck in the middle of a installation of windows. Best thing to do is to reinstall windows and let the cd format the hard drive, if it can't format the hard drive then the hard drive is bad and would need to be replaced.
Apr 23, 2010 | Dell Dimension 8250 PC Desktop
Primary disk drive not found
Check the connection of your hard drive and make sure it's plugged properly On The Motherboard.
Is this a SATA drive? Has it ever operated properly? If worse comes to worse, you'll have to reload windows from scratch.
Nov 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Hi My hard drive crashed can it is old can it be
Most likely scenario is the drive is dead, but also the BIOS on your computer is old itself, I believe there are a few BIOS upgrades available for that model, might want to check with Dell support site. If you have access to another computer, there is a way to check your drive. Go to a computer retail store or on Ebay, but a EIDE/SATA to USB adapter. This will allow you to take a hard drive out of the case and attach this adpter to it and plug the usb side into another computer, laptop, doesn't matter...that computer will read the drive as an external hard drive....if the drive is indeed still viable. If it is, this would be a good time to save your files to the other computer for safe keeping until you can get your other system back on its feet.
Oct 10, 2009 | Dell Dimension 4600 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 diskette drive 0 seek failure
Check your BIOS setting to see if it detects the hard drive (Primary disk 0). If it can't detect the hard drive then the hard drive maybe faulty. Open the case unpluge the IDE cable from the hard drive and reconnect it again, also unplug the IDE cable at the motherboard and reconnect it again including the power connector on the hard drive.
There maybe an option to test the hard drive in the BIOS, if so use it to test the hard drive.
If the hard drive is faulty, you need to replace it and install Windows, the various device drivers and your programs to get a functioning computer again.
You might consider buying a new computer (it will be faster & better than the old Dell) and you have your new monitor to go with it.
May 21, 2009 | Dell Dimension 2400 PC Desktop
Dell inspiron 5150 primary hard drive disk 0 not found
You may find that either the cable is not connected properly or is faulty, or the worse case the mother board has problems (driver, chips, breakages)
May even be a power supply problem, as the power supply has many output points and different voltages that the HDD power out may have blown. If it has then the rest of the system will appear to be ok.
So first off, check the cables connections on the motherboard, and look for any breaks in the cables, and if you have a power meter of some sort check the power connection, or plug in another power connector, the ones with the same end are generally the same power outputs. The ribbon cable for the HDD should have 2 sockets for HDDs and you must connect your HDD to the end one.
May 14, 2009 | Dell (U0614) for Inspiron 5150 60 GB Hard...
Dell 8250 Hard drive 0 not found after move from US to UK
IT sounds like the hard drive went bad, especially with the clicking noise. If you want to keep the system, you will need to buy a new drive (relatively cheap) from tigerdirect or newegg and istall it. NOt sure if dell still send out recovery cds with their systems but if you have one just insert the cd after you install the new drive and follow the prompts. If you do not have one contact dell support and they should beable to send you one
Jan 21, 2009 | Computers & Internet
Hard Drive
Put the CD in your CD Drive and shut off the pc. Then start it up again making sure the CD is still in the drive. You will then be asked if you want to boot from CD. Press any key to confirm this (it might skip asking you if it detects that your hard-drive is already blank) Then you want to let it run its install routine. Im not sure what options it will give you but the ones you are looking for is FULL install.
Aug 31, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 8200 PC Desktop Logo
177 people viewed this question
Alun Cox
