Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
WATER DISPENCER DOES NOT WORK, YOU CAN HEART THE MOTOR GOING BUT
MY ICE MAKER WORKS FINE, BUT MY WATER DISPNCER MOTOR COMES ON WHEN YOU HIT THEE SWITCH BUT NO WATER COMES OUT. HOW DO I REMOVE THE COVER OVER THE WATER DISPENCER?
    Habit-Forming:
  • 171 Answers
First thing to do is to remove the lower back panel behind the frige and disconet one of the water lines that goes to the top back of the frige and push the switch to get water with the line of. do that to the 2 lines one at to give you water back there. if none of the lines gives you water back there 100% that plastic valve needs replacing.
Posted on Dec 11, 2008
Ice maker/ water dispencer "locked"
have whirlpool ice and water waterand ice will not come come out--right no ice wil come push the ice have ice ill not go back to water
Sep 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Last night, I connected an active water line to the back of my Kenmore side by side. The ice maker is making ice but water water and ice is not coming out of the dispencer. There is another water jug...
You have a dual water inlet valve where your water supply connects. One goes to the ice maker and the other goes to the water dispenser by way of the water reservoir you mentioned in the fridge.
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
Apr 20, 2011 | Kenmore Side by Side Refrigerator
Ice maker dispencer motor won't spin. You can hear a click, and the ice dispenser light dims. The water dispenser works fine.
Best solution is to replace the ice maker. The ice makers are a cheap item and very hard to work on. It is easier to replace the ice maker rather than trying to take it a part and replaced the motor or gears. If you do want to take on the project you have to remove the ice maker and check the gears for a worn spot and the motor to see if it is still running. Parts can be purchased at a local appliance dealer. In tulsa we have Greers appliuances.
Nov 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not working
Cause could be the solenoid valve which controls water flow into the ice maker.
Could be bad solenoid, bad relay for solenoid, clogged solenoid valve, corroded electrical connections, etc.
More info? Let me know...
Charlie
Aug 14, 2009 | Refrigerators
Ice maker not making ice
i had same thing happen the line going to the ice maker was froze i too everything out of frezzer and let line unthaw for about an hour now works fine
Apr 28, 2009 | Whirlpool GD2SHGX Refrigerator
The water will not come out of the dispencer.
There is one water valve but two solenoids, one for the icemaker and one for the water dispencer. If power is getting to the solenoid then replace the water valve. No power getting to the solenoid then the switch at the dispencer is bad.
Feb 11, 2009 | Kenmore 53642 / 53644 Side by Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Whirlpool side by side
Hi, it sounds like you have a bad auger motor on your dispencer. If the button works for water, usually it will work for ice. It is also possible that you have a bad dispencer control board. If you would provide me your model # I could assist you further.
Dec 02, 2008 | Refrigerators
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
Kitchen aid superba fridge - ice maker not working .. water dispencer is
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
137 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
