Question about Bose 3 2 1 GSX System
Bose 321 DVD drive failure
I have an early BOSE 321 unit with a failed dvd drive (toshiba). Is there any source other than BOSE to obtain a replacement drive? The actual failure is at least partly a faulty tray drive mechanism. Thanks.
  • 7 more comments
  • Anonymous Dec 10, 2008
    I've had this problem at least 25 or 30 times in the 8 years I've owned the system, but tonight it was completely unfixable. I got so frustrated that I tore the damned tray open, recovered my DVD, and hooked up a cheap $29 DVD player's audio to the Bose's Video 1 input. Problem solved--and it cost me a lot less than the $400 Bose wanted to fix it.
  • Anonymous Dec 14, 2008
    how can i in on froze it my movie got stuckk inside
  • geekof5 Dec 26, 2008
    I have the same issue with my bose 321. Where can i find a replacement drive? I just tried a sony and that did not work at all. The sony is slightly shorter which I could deal with but it locked the bose up when I tried to access the drive with a dvd in the drive. Not real impressed with the bose.. I have had issues in the past with the drive ejecting and that is what is wrong now. I paid for what I thought was quality but Im not seeing that!
  • nick644 Jan 22, 2009
    wnewton839 Did the new drive work? Do you have an update? It would be great to plug in new udated drives to what is otherwise a good system.
  • Anonymous Feb 15, 2009
    i have he same problem BOSE Sucks Do not buy from them. I promise they will rip you off
  • luis_rios Feb 16, 2009
    I HAVE THE SAME PROBLEM WITH MY BOSE 321 SYSTEM. I NEED TO REPLACE THE INTERNAL DVD DRIVE, BUT BOSE WANTS ALOT OF MONEY TO FIX IT. PLEASE LET ME KNOW IF SOMEONE CAN HELP ME
    I HAVE THE SAME PROBLEM WITH MY SYSTEM I NEED TO REPLACE THE INTERNAL DVD DRIVE. BUT BOSE WANTS A LOT OF MONEY TO FIX IT. CAN SOME ONE HELP ME?
  • Anonymous Apr 04, 2009
    which site posted the procedure to replace the drive?
  • slammer1989 Apr 15, 2009
    Same issue, found the drive on-line a place called Impact Computers and Electronics Part Number SDM-1612 (Toshiba DVD drive) $70 plus S&H
    Got the old drive out, new drive in but the door will not open
    I swapped some plastic parts but not the metal outer cover (guess I will try that now, 15th time taking the damn thing apart)
    Wish me luck
Found another help site similar to FixYa where a person had posted that they successfully replaced their failed DVD ROM drive in their BOSE 3-2-1 Series I unit with a later model Toshiba SD-M1712 drive. There are 2 plastic trim bits and the metal DVD drive unit cover that need to be swapped between the old drive and the new PC type drive to complete the repair. I located and ordered a new drive and spent last evening removing the old drive from the BOSE. To remove the old drive all that is really necessary is to remove the lid from the BOSE unit and pop off a black steel holdown assembly across the top of the failed drive. Once that is done the old just drive lifts out and the replacement is virtually the same as swapping out a drive in your PC. I am awaiting arrival of the replacement OEM drive ($25) from some place in Texas. This just may work. BOSE wants hundreds of bucks and several weeks to repair their crappy unit. I will never purchase BOSE again. I had to also purchase a power supply in years past for this very lightly used unit and that was $300 and a lot of aggravation using the BOSE repair system. I have trouble just throwing this unit away because we spent $1000 hard earned $'s to buy the "best". I was certainly fooled. If this doesn't work I'm only out $25.
Posted on Dec 10, 2008
I just ordered a dvd/cd player form newegg for 18$. Think it was a Model DDU1678A sony IDE!. I just poped the top of the 321 (first version) took off the plate holding the rom player down and removed the old one and put the new one in. (Your going to have to open the door on the cd player to get it out and in plus unclip the Bose door form the old rom door too). Also I had to pry the front off the new player to get it to open and close in the bose unit. I just use the old bose door as a plug for the hole but I guess you can use some spacers and glue it one if you want. All in all it was easy to do that is if you do it for a second time. Take care of the power plug on the back of the cdrom also two wires fell off the plug after playing the remove and install game to many times trying to get the darn thing in the first time. I had to take the wire bundle out and push the wires back in the clip of the plug.. major set back. All in all its works now, the cd rom spins up kind of lound also but will quiet down. Not a big thing the person that uses it has a dvd/tape player hooked up to it. The only reason I had to put a new rom in it is because if you unplug the old rom it will not turn on at all least this one didnt.
Posted on Jan 30, 2010
  • 2 more comments
  • lsjdesigns29 Dec 11, 2010
    I just install a new DVD drive to my Bose 321 (Version 1). I wished I had made a YouTube video. Pretty easy and simple to do. Paid $17.00 for the drive. Popped it in and everything is working just like the day I bought it.
  • jalmeida1967 Feb 20, 2011
    What type of drive did you replace it with I too am having the same problem. The drive I have is a Toshiba SD-M1502. Not sure if I replace it if tthe Bose is going to check the ROM version of the drive.
  • cmolina1170 Feb 24, 2011
    I tried the sony drive on my 321 system that had a SD-M1502 and it did not reconize the sony drive. so i opened the orig. drive and adjusted the gears and mechanism that opens the tray and now it works fine. it seems the mechanism moves to far from the gear to engage and open tray.
  • David Pierri Jan 11, 2013
    All my player needed was a drop of machine oil in the DVD ROM motor and it's back to business.
Just look at this video(see link below). I bought a dvd player for â'¬10,-. I learned from this this video and got the rigtht instructions. Finally made it working again. Bose charged me â'¬150,- for this. Who is a fool? http://www.youtube.com/watch?v=fFCCYCSwBPU
Posted on Mar 28, 2011
  • rupiklayo Mar 28, 2011
    Dvd player Toshiba sd-m1712
Bose 321 not recognizing cds
Contact Bose and send your unit back. Most likely the CD/DVD drive needs to be replaced
Dec 06, 2013 | Bose 3 2 1 GSX System
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
Bose 321 won't eject DVD
the dvd system is built around a pc style dvd rom drive. You can remove the top cover by prying the back center up and sliding the cover back then off. Remove the metal bracket that holds the drive in place and then remove the drive. the front tray cover should pop off as you remove the drive. There is a eject hole in the front that if you put a paper clip into it will release the tray. That way you can get your dvd back. I refurbish these drives and I may have one for sale. Contact me if you would like to send the unit in to me i can complete the repair for 85.00 Bose does offer a repair service if you call them at 1-800-999 2673
May 02, 2010 | Bose (321GS) System
Hooking up dvd player to Toshiba DPL 52" HDTV
Send the viseo to the Tv using composite or component input and send the audio ( red and white RCA audio ) to the BOSE.
May 13, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
Nov 23, 2008 | Bose 3·2·1 II System
Non bose dvd player for bose system
In short, you can. I did it last night. My Bose 321 DVD player is junk and it's always been junk, but I love the sound sytem. Last night, after the thing gobbled it's last DVD, I went through the whole, unplug, wait 5 minutes, plug back in, etc. and it still wouldn't eject so I ripped the DVD tray out of the thing with a pair of pliers, recovered my DVD, and slammed the tray back in, stripping all the gears and screwing up the motor in the process.
BUT, I disconnected the video cable from my Bose and plugged it into the video out on my el-cheapo Tru-Tech $99 DVD recorder. Then I ran the audio out cables from the Tru-Tech to the Aux 1 inputs on my Bose 321.
When I want to watch a DVD now, I put the DVD in my Tru-Tech, turn on the Bose, switch it to Aux 1, and I get a great picture and the Bose sound. Best of all, I don't have to plug and unplug that sorry Bose system everytime the wind blows.
They used the absolute cheapest DVD player they could get their hands on--a Toshiba model--for all the Bose 321 older models. Every single person who bought one has had these same troubles and they've made no offer to fix them.
This was my first and last Bose because of that and I hope more people stay away from Bose until they get their act together and protect their customers. $1000 for a system that eats DVDs like M&M's is ridiculous.
Aug 08, 2008 | Bose Lifestyle 28 System
Bose 321
yes as long as IDE cables and DVD player fits it shouldn't be a problem
Apr 24, 2008 | Bose (321GS) System
Bose 321 won't play CD and VCD but plays DVD
I did have the same problem. Then unplugged / replugged the base cable (= also the power supply) and after this the Bose dis play CD's again.
Feb 29, 2008 | Bose 3·2·1 II System
Bose 3 2 1 GSX System Logo
8,249 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
