Question about M-Audio StudioPhile DX4 Main / Stereo Speaker
Fuse keep blowing
The red and black wires to the next specker was in contact with each other
  • 75 Answers
Seprate the wires to get good sound...
Posted on Dec 09, 2008
40amp fuse to fuse block keeps blowing (fuse #3 in the manual)what color is the wire off this fuse so I can trace this to the fuse block this is on a 1992 jeep Cherokee laredo
Confused. #3 in the diagrams is 10 amp dome light. Are you talking about the starter relay fuse that powers the solenoid? That circuit has a red wire from the ignition switch to the fuse. After the fuse, the wire is black/red to the start relay. After the relay, the wire is brown to the starter solenoid.
Sep 15, 2017 | Cars & Trucks
30 amp fuse keeps blowing
check for hot wire with cut in insulation either by frame or going through frame probably red or black wire also check lights and plug
Sep 20, 2015 | Jayco 2014 White Hawk Ultra Lite 24RBS
I soldered all the connections on my stereo system and I keep blowing my 5amp fuses I have the yello wire from the head onto pos + on my then I have the black wire on neg .also my red wire is on neg.
check the wiring as the red wire may be a positive power in wire and if you have it on the negative terminal that would amount to a dead short and that would blow the fuse
consider changing the yellow from the + terminal and putting the red wire there and if it stops blowing fuses the put the yellow wire on to the - ve
if that means that the unit doesn't work then touch it back on the + terminal
if that works the solder it there
Aug 13, 2015 | Cars & Trucks
I connected the red wire to the positive and the black wire to the negative but the 30 amp fuse keeps burning out immedietly and my diaphram pump won't turn on at all. What is going wrong?
The problem must be in the pump if the fuse only blows when you connect the red and black wires from the pump, that's all I can think that it might be as long as you are following the installation instructions
Jul 27, 2014 | Cars & Trucks
A/c compressor keeps blowing fuse
Disconnect The AC compressor clutch, does the fuse still blow.
Oct 21, 2012 | Cars & Trucks
Newer radio not working
Back-up and ONLY connect your red yellow and black wires. Are you still blowing fuses? NO? good... next check your illumination and dimmer wires (the orange and orange/white) if those get mixed up, you will also blow fuses.
IF you blow fuses with only those 3 wires connected, it's likely you have something exposed and touching.
Jun 29, 2009 | Car Audio & Video
Difficulty wiring into GM harness
well if your trying to actively wire it up with the car battery still connected that is why you are blowing fuses. just a heads up too if you have a live connection while hooking up the cd player you could short out other electrical devices and you could be in alot more trouble thatn just blowing fuses. the black wire is what is blowing fuses its because you have it hooked up wrong to a wire that is sending voltage not recieving voltage. ground the black wire to the actual chassis instead of hooking it to the ground wire from the harness or whatever color its grounded to which shouldnt be anything but black if you have the black wire hooked up to ANYTHING that isnt black that is why you are popping fuses. so hook up the red yellow and make your own ground you shouldnt have any problems after that.
May 08, 2009 | Car Audio & Video
30AMP FUSE KEEPS BLOWING WHEN I CONNECT THE BATTERY
i have had that happen when i accidentally hooked cables backwards to battery.red cable(pos) to post w/ + next to it & black cable(neg) to post w/ _ next to it is correct.
Feb 16, 2009 | 2003 Triumph Daytona 600
M-Audio StudioPhile DX4 Main / Stereo Speaker Logo
202 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
SHIVAJI YADAV
SHIVAJI YADAV
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
