Question about Sony VAIO PCG-K23 Notebook
How do i remove the back off a sony vaio to replace usb ports? i have took all the screws out but do not want to put to much pressure on as do not want to break it! (Repairing it for a friend)
  • deb_my Dec 10, 2008
    This is actually a faulty port problem. Both ports have been damaged.
    Will I have to replace the motherboard?
    Scholar:
  • 86 Answers
You cannot easily replace the usb ports as they are soldered as part of the motherboard. If the ports are not working then go as follows and attempt to reset them
I'm going to assume that you're running XP (home or pro). . This is the sequence to use
1. Right-click My Computer and select Properties
2. Click Hardware
3. Click Device Manager
4. Expand the Universal Serial Bus Controller
5. Right-click each USB device listed and select Uninstall
6. Click OK to confirm removal of each device
Note: Repeat steps 5 and 6 until all devices under UBS Controller are removed
7. Shut down computer.
CAUTION: Ensure that the Shut Down option is selected instead of Restart.
8. Wait a few seconds and turn computer on. When it reboots you will see "Windows has detected new or added hardware"
Note: You will have to insert your Windows CD, if prompted.
These steps will refresh the USB ports.
Added Notes: 1) If your mouse is a USB you will have to use the keyboard to shut down your computer. 2) It would be wise to unplug everything from your USB ports EXCEPT your mouse and/or keyboard before you restart the computer to avoid Windows replicating any printers, scanners, digi-cams, etc. Once Windows has refreshed your USB controllers and ports, shut down again. reconnect, and restart.
Good Luck
Posted on Dec 09, 2008
  • wigglybus Dec 10, 2008
    As I said, it is not really practical to physically replace the usb ports. if you have a serial port on the laptop then you could usean adaptor such as those on the Ebay link below
    http://shop.ebay.co.uk/items/_W0QQ_nkwZs... If no serial port then the only other way is to replace the motherboard.
    But really, it's not worth the effort Don't bother - just buy another and get your data transferred. Go for a used Dell D610. Excellent machines, about 4 years old now but I sell loads and NEVER had a problem. Good build quality, unlike most of todays laptops
Remove keyboard 646125-001
  1. Prior to replacing your replacement keyboard for sony vaio vgn-fe880e/h, make sure to remove the keyboard and disconnect the ac adapter from your laptop.
  2. The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
  3. Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
  4. Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
  5. To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
  6. Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
  7. Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
  8. Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
Nov 30, 2012 | HP 646125-001 - Keyboard Tm - Us
How do you open a sony vgc js160j all in one pc that has everything attached in the screen?
just remove the screw at the back. don't worry about the ports that is intact with the motherboard. after removing all the screws, use a precision screw to open the lid off. then your good to go.
Jul 01, 2010 | Sony VAIO VGC-JS160J/S Notebook
My USB Ports of Sony Vaio VGN FW235 stopped working
first remove all the USB Devices connected to the Computer, go to Device Manager, uninstall all the USB Drivers and restart the Computer. after the restart, the Operating System should reinstall the USB Drivers automatically as the USB Drivers are Operating System generic.
If this does not work, go to Device Manager, right click on the USB Device having Yellow Exclamatory mark and click on Update Device/Driver and select search for the best driver in these location and in the location type C:\Windows\inf and click next.
This should resolve the issue.
If this does not work, you can try performing the System restore where the USB ports are working normally.
May 26, 2010 | Sony VAIO VGN-FW235J Notebook
Scrolling/cursor problmem on Sony Vaio VGN-C140G laptop
Im having a similar problem , have you got it fixed yet? I really need some help the scrolling feature on my Vaio VGN - FZ31S does not work at all and I have tried everything.
Feb 20, 2010 | Sony VAIO Notebook
Sony vaio aw11m- took it apart now cant put back
You need a technician to reassemble it. There are no diagrams detailing every screw.
Good Luck!
Oct 30, 2009 | Sony VAIO VGN-AW110J/H 18.4-Inch Laptop...
Sony vaio vgn-fs630/w. the ethernet port and usb ports not workin
The best thing you can try is a Static discharge.
Please remove all the external devices. Unplug the power adaptor.Remove the battery. There should be no electricity connected.
Then press the power button and keep your finger on it for about 30 seconds to release any build up electricity.
Plug in the adaptor and battery again and see if there is still a problem.
Maybe is a good idea to get a surge protector in the future.
Regards,
Purito
Oct 17, 2009 | Sony VAIO VGN-FS630/W Notebook
How to install cd rom in sony vgn-fs980
Pretty simple. There is only one screw on the bottom of the laptop that secures the cd. Remove the screw, pull out the module, and replace with a new one. Don't forget to put the retainer screw back in.
Mar 12, 2009 | Sony VAIO VGN-FS980 Notebook
Sony pcg 9h4l motherboard issue
Try to power off unit and remove the battery. Then press and hold power button for 30seconds.Put the battery back and turn it on. If it turns on turn it back off again and remove the battery. Connect your VAIO using the AC adapter only. If this will not resolve your issue you can check this with SONY or any certified service center.
May 23, 2008 | Sony MBX-49 ASSY Motherboard
Sony VAIO PCG-K23 Notebook Logo
156 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
