Question about Toshiba 62HM95 62" HDTV
Light blinks wont start up When I turn on the TV, the red light comes on, I hear some high pitched whirring and the green light will flash 8 times. Then the TV turns off and the red and green lights will flash simultaneously. The red light will come on as the TV tries to start again and then the process will repeat. I have replaced the light bulb 1 year ago.
  • 734 Answers
Ok,
what i want you to do is to disconnect everything from your tv set cable box,surround sound ect.... before trying this unplug your tv set from the wall wait for about 15 minutes then plug it back on and turn it on see what happens.
Thankss
Posted on Dec 09, 2008
    Genius:
  • 2,920 Answers
The flyback is out on the tv thats the noise you hear
  • Toshiba Master
  • 19,396 Answers
That means that the TV is in protection mode, because of an internal fault, start unplugging the power cord for one hour and see if this clear the error.
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
Green light flashing, bulb will not turn on, green light sometimes goes to red flashing light
check the lamp. does it have bulges, black spots, flaking or fogging? if so replace it. aslo if the screen on the side is clogged with dust. if the lamp is ok, check the colorwheel. if you don't hear a high-pitched whir when you turn it on, the colorwheel motor is bad. replace the colorwheel. check the fans, too.
Mar 23, 2010 | InFocus X1 Multimedia Projector
Light flashing red, projector will not come on. Turned off and when turned back on the light is green and then flashes red a few seconds later.
do you hear a high-pitched whir when you turn it on? if not, you have a bad colorwheel that needs replacing. the lamp won't turn on if the colorwheel is not spinning. also check the fans. you can get the part from an infocus service center or send it in to them for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 20, 2009 | InFocus ScreenPlay 4805 Multimedia...
Projector was turned off wrong and now wont turn back on.
if the led flashes once in 2-second intervals and you don't hear a high-pitched whir, the colorwheel needs replacing. if you do, the ballast is bad. if it flashes 2 times, the lamp is past 3000 hours. 4 times, fan error. 5 times, temp too high and it needs to cool.
Nov 07, 2009 | InFocus ScreenPlay 4805 Multimedia...
Unresponsive, lamp dies upon start
if you don't hear a high-pitched whir, the colorwheel is shot and needs replacing. if you do, one of the fans might not be working and the heat shuts it off so as not to cause damage.
Oct 15, 2009 | InFocus ScreenPlay 4805 Multimedia...
Benq pb8250 , red light blinking
you have a problem with either the fans, the ballast, or the colorwheel. if the fans turn on, listen for a high-pitched whir. if you don't hear it, replace the colorwheel. if you do, replace the ballast. if the fans don't spin, replace them.
Sep 22, 2009 | BenQ PB8250 Multimedia Projector
I got a free sharp notevision PG-m20x. I plug it
if you don't hear a high-pitched whir, the colorwheel needs replacing. if you do hear it, the lamp may need replacing. if the lamp is new, there is a power supply problem.
Sep 04, 2009 | Sharp Notevision PG-M20X Multimedia...
Unit powers on but green light flashes and no projection
if you hear a high-pitched whir, the lamp or ballast may be bad. if you don't hear a whir, the colorwheel is bad. the lamp won't turn on without the colorwheel.
Jun 09, 2009 | InFocus LP70+ Multimedia Projector
Toshiba 62HM95 62" HDTV Logo
111 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
