Question about GE JVM1440 Microwave Oven
Howv do you remove plastic grill above the door on a GE 1400 spacemaker to dust of the fins
  • GE Master
  • 9,086 Answers
Your owner's manual should cover this, but if for some reason you don't have your owner's manual, you can download GE owner's manuals and installation instructions here.
Usually you just remove the two screws on the front of the top cover of the microwave (or in the grille itself) then lift up/out on the grille, as shown in the drawings below.
Posted on Dec 13, 2008
Remove grill ge spacemaker xl1800
LOOK ON TOP FOR 2 SCREWS OR IN BETWEEN LINES ON THE FRONT OF THE PLASTIC GRILL.
Oct 13, 2012 | GE XL1800 1100 Watts Microwave Oven
The interior bulb of my ge spacemaker oven jvm1490sh01 has blown out. How do I go about replacing it? Thanks
HI,
I looked up your model and found that if you remove the grill above the door, you can ***** the bulb area. With the grill removed, in the middle left side, you will see either a black or metal looking cover, if I remember correctly you slide the cover back toward the wall and lift up. There is where your bulb should be.
If you would like unplug the micro way before you enter this area for safety only. I normally don't but I know what I am looking for.
Good luck, be safe
Jul 23, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The door handle on my GE spacemaker xl 1400 microwave is broken (plastic). How do I fix this.
By replacing with new one for sure... You can find them on amazon, here: Amazon com ge spacemaker xl handle. I hope this was helpful. Cheers
Nov 14, 2010 | GE Spacemaker JVM1740 Microwave Oven
GE Spacemaker 1400 acts like everything works but does not heat.
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck
Apr 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to remove ge spacemaker 1400?
You can download GE owner's manuals and installation instructions here.
Aug 18, 2009 | GE Microwave Ovens
Remove old over range microwave
Are there any metal or plastic grills above or below the microwave--if so remove them and unit should just slide out. If no grills, the feet of the unit may be dropped into shallow holes bored into the shelf under it.
Aug 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave mcd11e3b
Hi, This is the info I gave another user yesterday:
Hi, Remove the 2 screws in the grille, the grille pulls straight out (with the door open is a little easier). Then above the light is a cover plate which is removed by the two screws on the plastic frame. You will see a little tab that allows you to lift that cover plate out gaining access to that bulb. As always you should be safe and turn off the power before you repair any electrical device. Good Luck!
Feb 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Light replacement
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1440 Microwave Oven Logo
60 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
