Question about Epson Stylus CX6400 All-In-One InkJet Printer
Blank pages from printer
The printer will not print. tried changing ink cartriges, cleaning nozzles. re-installing drivers and all other actions I could think of and the printer does not print. Help!
    Sergeant:
  • 390 Answers
Ahhh We love printers don't we??? Not!!! How did you clean the nozzles. Did you use the printers own maintenance system or did you do it manually. The printer can never clean them as well as you can manually, and this is probably 90% of the cause of blank pages. Clean rollers too while you are at it. Use a proper cleaning solution, and cotton buds, and clean where the cartridges go in, and the heads too. The next possibility is that the printer is set to pause, or print offline, go to your print settings, scroll down to properties and make sure thes two items are not checked. If so, unckeck them. Lastly, the drivers itself could be corrupted, and may need to download new updated drivers from epson website. Good luck
Posted on Aug 30, 2007
Lexmark wireless printer 1400 series prints blank pages
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark Z1400 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Jan 22, 2012 | Lexmark Z1420 Printer
Colour ink not printing
If the printer is printing blank pages, make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the "Ink" option in the printer driver may be set to "Black" instead of "Color" or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged.
A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, turn the printer off overnight and try the cleaning cycles again.
Try a new ink cartridge. Also, make sure you are using a genuine ink cartridge and has the same number as your old catridge.
Jun 20, 2011 | Computers & Internet
Epson C63 will not print despite having changed all the inks. It tries but the paper is blank
I think there are 2 causes epson c 63 printer not print problem.
First one is: Your ink cartrige are not install properly.
Solution: Try to install ink cartrige properly, in this time please clean ink cartrige chip as well as connector.
Secoundly: printer main board problem. Print data does not pass through main board.
Solution: Please replace new one.
I think you will relive from the problem.
Thank yoou.
Feb 28, 2011 | Epson Stylus C63 InkJet Printer
No ink on printed pages
Try to pull out the ink cartridges. Then after 1 minute put the cartridges on. Then it will initiate head cleaning. Just perform the head cleaning to clean clogged nozzles. Then try to print a test page.
May 10, 2010 | Brother MFC 490cw Color Inkjet...
Epson stylus dx4000 printing blank pages . how do
replace cartriges, clean printers heads from utility menu
Oct 25, 2009 | Office Equipment & Supplies
Blank pages
tried re-installing the sortware or going into printer diagnostics in the start,control panel.
and it will run a diagnostic & try to print a test page, & clean the cartriges.
If not the printer's broke
Hope this help's
Sep 22, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Cant get printer to work
Have you tried a cleaning cycle? If not, try one. Now run a nozzle check using the status monitor (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more
cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back.
There is also the "generic" approach. Turn the printer on, and as soon as the print head starts to move, pull the power lead out of the printer, or turn it off at the mains. The print head should now be free to move (gently!) by hand to the cartridge change position. The snag here is there is no inherent means of running an ink charge cycle - do a couple of head clean cycles instead.
Jul 29, 2008 | Epson Stylus C68 InkJet Photo Printer
Blank Pages HP Officejet d125xi
Here are a few things to try: 1. Remove and then reinstall the ink cartridges 2. Clean the ink nozzles because they may be clogged which can be done manually or sometimes using the printer control panel like so: Open the print or fax window > right click on ink jet printer icon > select Properties > on the general tab click printing preferences > click services tab > click clean the print cartridge. If you have this option it will automatically clean the print nozzles, if not you will have to do it manually (check your documentation if you still have it for details on how to do this). Take cu-tips and remove the ink cartridges > dip the cu-tips in distilled water (not tap water) and squeeze any excess water out of the cu tip > Hold ink cartridge so that the nozzle plate faces up and use the swab to wipe clean the area around the nozzle plate > Hold cartridge up to light to make sure all dust, dirt, dried ink, or cotton fibers are not left behind > Dry them off and replace into printer and print a test page. 3. Try different settings for the print quality to see if any changes occur. 4. Turn the printer on and leave it on for about 30 minutes to warm up to loosen or melt any dried ink that may have blocked the nozzles. If this does not work there may be more serious problems that will require a qualified technician to deal with. Hope this helps and let me know if you need further assistance.
Jul 05, 2008 | HP OfficeJet D125xi InkJet Printer
Printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Jun 17, 2008 | Epson Stylus C60 InkJet Printer
Blank Pages Printed
Remove the protective tape from the cartridges:
With the printer power on, open the front cover of the printer. The cartridge carrier should move to the middle.
Remove the cartridge(s) from the printer.
Look on the underside of the cartridge(s). If there is yellow tape and/or transparent blue tape there, remove it.
Clean the cartridge nozzles:
Go to the Lexmark Control Program or Solution Center and run the Clean print nozzle test.
If a black cartridge is installed, you should see black lines only.
If the color cartridge is installed, you should see yellow, magenta (a reddish purple), and cyan (a dark sky blue) lines.
If a photo cartridge is installed, you may see different colors.
Examine the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right, with no gaps.
If there are gaps in the lines, you could run the Clean Print Nozzle page a few more times to try and clear it up or try the "wicking" procedure below to conserve ink.
If the page is faded from left to right and the wicking procedure doesn't clear it up, your cartridge is probably out of ink.
Clean ("wick") the cartridges:
Remove your cartridges following the instructions in your User's Guide.
Take a warm, damp paper towel and fold it so that it has about 4- to 6-ply thickness.
Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge.
Now drag the cartridge lightly across the paper towel in one direction only (left to right) until the bottom of the cartridge looks clean.
Turn the cartridge over so that you can see the bar code sticker on the back. Note: Only perform steps 6 and 7 if the contacts look dirty or corroded.
Using a clean pencil eraser, clean the contact points on the copper strip (only the little squares just below the bar code). Caution! Do not use the eraser on the nozzles that were cleaned, as this will damage the cartridge.
Using a clean part of your dry paper towel, wipe the eraser dust off the contacts; ensure that they are dry, and snap the cartridge back into the printer.
Make sure to install the cartridges following the instructions in your User's Guide, selecting Old Cartridge. Failure to do so could reset your ink levels as explained above.
Repeat the nozzle cleaning procedure one more time. At this point the diagonal lines should be solid.
If they are not and you think the cartridges should have ink in them, contact our technicians by e-mail and let them know the results of this test.
Reset the ink levels:
Lexmark printer cartridges do not have ink sensors. The levels of ink are produced by a mathematical calculation of ink drops and page counts. The printer stores this information and then writes it to the win.ini file on your computer.
Ink levels can be reset by telling the printer you have installed a new ink cartridge or by reinstalling the printer drivers and selecting Cartridges Installed. Once ink levels have been reset, there is no way to change them except by printing.
Accordingly, even if your computer says that your ink is full for a particular cartridge, it may be incorrect and the cartridge may need to be replaced. You may want to try a new cartridge to see if that clears up any print quality problems.
Mar 13, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Epson Stylus CX6400 All-In-One InkJet Printer Logo
87 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
