Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Can't get it from Roller Brush Off to Roller Brush On
Mine is actually the Hoover U6485-900 Windtunnel Anniversary Bagged Upright.
It constantly stays in the Roller Brush Off. I have changed the settings for carpet height and from floor to carpet and back and forth and it never changes. How do I get it to go to Roller Brush On?
  • Hoover Master
  • 19,396 Answers
On some model there is also a plastic tab to unlock the roller brush, check it out. You must also have the right tool installed.
Posted on Dec 09, 2008
  • 734 Answers
There is a user manual for Hoover U6485-900 ---
http://homeappliance.manualsonline.com/manuals/mfg/hoover/u6485900.html
Thankss
Drive belt on Hoover U6434 keeps slipping off. Even new ones.
Check the motor shaft for residue from a previously burned belt. Also the brush roller may be defective.
Jun 08, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
U6485-900 WindTunnel Self-Propelled I changed the belts but there is not enough tension on the brush drive belt to get it to rotate
I had the exact same problem with my Hoover U6485-900 Anniversary upright, self propelled, vacuum. It would move backwards and forwards, had good vacuum, but wouldn't pick up much because the brush/roller was not turning very well. I replaced the main drive belt (38528035) and it now works great. The old belt had stretched and was slipping under load. Thanks for the great suggestions.
Aug 02, 2013 | Hoover U6485900 Bagged Upright Vacuum
Hoover upright bagless vacum.motor runs, brush turns, no suction through hole behind brush roller. however there is suction going out of dust cannister filter flap to motor. what could possible problems...
Sorry to read about your problem, I hope this helps you out.
you have a clog between the brush and bag
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
HOOVER WINDTUNNEL SELF PROPELLED OVERHEATING AND SHUTTING OFF
It sounds like it is overheating because of a blocked flow of air that keeps the motor cool. Check for a blockage from the area of the
roller brush through the hose to where it goes into the bag.
Tom
Oct 22, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Jul 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Just looking to see if worth repalce roller or
just look to see if you can get the rollers replaced.
Jul 02, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Automatic brush roller turned off
This model you will tilt forward and then change the carpet knob to bare floor
Feb 01, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Roller Belt Keeps Slipping Off
You could try contacting Hoover for parts availability. If it's and older WindTunnel and Hoover no longer has the part, try eBay.
May 14, 2017 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush roller on Hoover upright stops turning
There should be a belt tensioner for the V belt, maybe it is not contacting the belt when you tilt the handle back. If this is less then 1 year old, then it is under warranty, take it in to a warranty servicer for warranty repair.
Dec 13, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
137 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
