Question about Daewoo DSJ-5510CRA 55" Rear Projection HDTV-Ready Television
GHOSTING The top of the picture all the way acroos the tv is fuzzy. I called a repairman and they replaced a board they say was "leaking" oil. It did not correct the problem. Last month I had put on a 3D DVD and a few adjustments had to be made on the tv to view in 3D. How do I reset the TV back to factory presets? Te tv repairmen left a stated the dvd might have broken a computer chip in the TV.
    President:
  • 1,284 Answers
First of all boards don't leak anything. The leakage was caused by one of the projection tubes leaking its coolant. If the faulty tube wasn't repalced then you will start all over again with the same issue and cause more damage to the TV. Not only that but the loss of coolant in the tube will cause the picture to be partially out of focus (the defectinve tube that is). DVD players don't break ANY chips inside of the TV. Sounds like a repairman who doesn't know what he'she is doing and needs to exit this type of work.
Posted on Feb 27, 2007
The picture is very wavy and fuzzy sound is perect
Depending on the specifics of your tv (flat screen LCD, LED etc, Plasma, or CRT)
Unfortunately sounds like ghosting / indicative of Bad Panel.
BUT to be sure ...
Double check picture settings to be sure setting inadvertently changed. try using Component to be sure connection isn't problem
Mechanically
COULD also be defective T-con, or in plasma a sustain board can create issues. (for a TV shop to determine/ high voltage is present so not for the untrained)
Mar 30, 2018 | Televison & Video
Tv clixs on and off
check the capacitors and replace the power components.. if not handy with soldering electronics call Tv repairman as you may need to replace capacitors and possibly mother board .. Tv repairman may charge 75-150 dollars depending on cost of Mother board .. good luck
Sep 21, 2012 | Sanyo 42 in. LCD TV
Blue shadows and a yellow and blue arc acroos the bottom of the screen
Tv have a problems known as a convergence problems it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 02, 2011 | Pioneer SD-582HD5 58" Rear Projection...
We turned the TV on and there was a rainbow curvy lines acroos half the screen
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 02, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Our tv just started having a fuzzy image and the auto focus function aborts during the red color alignment. is there a manual alignment I can do to fix it.
What does this fuzzy image look like? Does it have ghosting shadows. Of course it is possible to align red manually from the convergence menu. But first lets confirm that it is indeed a convergence related problem.
Aug 18, 2010 | Samsung HCL552W 55" Rear Projection...
Sony Bravia with really bad ghosting
The little board on top attached to panel.
Jul 05, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
Fuzzy picture, can't read the on screem menu to
problem is inside tv,,, a component called as picture tube base is got problem ,,pictube base connects the picture tube to the circuit board inside ur tv..call aservice men to replace it
Mar 18, 2010 | Televison & Video
Picture becomes fuzzy and lined, clears with a sharp rap on the top of case.
probably a bad connection on the circuit board inside that heats up over time. the tap on the top probably moves the connection just enough To make it good for short time.
Feb 02, 2018 | Hitachi 60UX54B/55K 60" Rear Projection...
Ghosting in red ,blue & green
Sounds like an allinment problem with the color projection you can allin yourself via small screws on color tubes in rear. but be careful as tv needs to be on to do it.
Jul 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Daewoo DSJ-5510CRA 55" Rear Projection HDTV-Ready Television Logo
178 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
