Question about GE Telephone pr521w
Storing Speed Dial Phone Nmbers
I have an old GE Answer-Phone (model #2-9821) that works fine but I don't know how to store phone numbers into memory for the speed dial feature. The answering part of the machine (digital) works fine but I would like to use the speed dial feature. I don't have the owner's guide and can't find one available on-line or from GE (Thomson). Can anyone help me? Thanks. Bill from Danbury
  • mylady59 Feb 22, 2008
    I cannot add numbers to my GE 900MHz cordless phone...can't find the manual...have numbers in there but need to add more...help?  thanks
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Posted on Jun 06, 2009
    Problem Solver:
  • 7 Answers
Yvonmtl,
Thanks so much. My dad has early stages Alzheimer's and didn't want a new phone but was having trouble remembering my phone number. I couldn't find his manual and couldn't find one on line.
Your solution worked great. God bless you.
Tom
Posted on Feb 15, 2009
Quick Dial Numbers: 1. PICK-UP Hanset 2 PRESS STORE IN - DIAL Phone Number - PRESS STORE IN - PRESS A or B or C 3. HANG UP 4. WRITE name or number of party store in corresponding MEMORY location on Directory Card. Frequently Called Numbers: 1. PICK-UP Hanset 2 PRESS STORE IN - DIAL Phone Number - PRESS STORE IN - PRESS 1 to 9 (PRESS Memory Location Number) 3. HANG UP 4. WRITE name or number of party store in corresponding MEMORY location on Directory Card.
Posted on Aug 27, 2007
SOURCE:
I have a VTECH phone model Vt 1122 and I do not have manual still and I need to know how to insert numbers in memory.
You can get the manual here. Here's what it says about storing numbers:
Storing a Phone Number in the One-Touch Memory Locations
  1. Lift the handset.
  2. Press the PROG button.
  3. Dial the telephone number you want to store (up to 16 digits).
  4. Press the one-touch button (M1, M2, M3) where you want to store the number.
  5. Hang up the handset.
Storing a Phone Number in the Two-Touch Memory Location
  1. Lift the handset
  4. Press the MEM button.
  5. Press the dial button (0 to 9) where you want to store the telephone number.
  6. Hang up the handset.
Please take a moment to rate this solution if it's what you needed. Thanks for using Fixya!
Jul 04, 2011 | Vtech Lands Phones
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
How do you set up speed dial?
http://www.home-electronics.net/ge/pc/IB/29385GE1_IB.pdf
here is the owner manual , to much to type , but start at storing a phone number in MEMORY , start reading at the word MEMORY in the user guide .you need to list a phone number in memory and then assign a number to it for future speed dial , yet they use the term memory . can be accessed while on the hook or off .
Jan 01, 2009 | GE 29385GE1 Speakerphone
Instruction manual for older style corded GE speaker phone
Here are the quick instructions on how to program the phone numbers.
You can also download a copy of the User's Guide from: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=c96e9c823d0df43989039e5385bef04a&q=GE+29322GE1
Just enter the 4 digit captcha code and you will be able to download the User's Guide.
Please let me know if yo have any questions.
Good Luck!
STORING A NUMBER IN MEMORY
To program priority keys:
1. Make sure the telephone is properly installed. Pick up the
handset and listen for the dial tone. If you don’t hear the
dial tone, recheck or repeat the installation steps.
2. Press the SPEAKER button or pick up the handset.
3. Press the store button.
4. Dial the number to be stored.
5. Press the store button again.
6. Press the A, B or C button.
7. Press the SPEAKER button or hang up the handset.
To program frequently called numbers:
1. Press the SPEAKER button or pick up the handset.
2. Press the store button.
3. Dial the number to be stored.
4. Press the store button again.
5. Press one of the 10 memory location buttons 0-9.
6. Press the SPEAKER button or hang up the handset.
Aug 11, 2008 | GE 29322GE1 Corded Phone
Uniden 900MHz phone model EX17960A
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
7
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
will return to standby mode.
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
Nov 13, 2007 | Lands Phones
Storing memory numbers
1 - Lift the receiver and get the dial tone.
2 - Hit 'Store'
3 - Enter the number you wish to store in the phone
4 - Hit the store button again
5 - Hit the memory button you wish to store the number into
6 - Hang up!
This should store the number wherever you want to put it. Remember if you want to store it in one of the 'lower' positions (second line of the memory index card) push the 'Shift' button before you push the memory button for that location.
Oct 06, 2007 | GE 2-9438C Corded Phone
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
Programming
MEMORY
Store as many as 12 numbers in memory for easy dialing. Three can be stored in the Emergency Quick Dial locations, and nine additional numbers can be stored in the numbered keys (1-9).
1. Press SPEAKER (or pick up the handset).
2. Press STORE.
3. Dial the number to be stored (up to 16 digits).
4. Press STORE button.
5. Press a Memory Location (1-9 on the keypad), or an EMERGENCY QUICK DIAL button.
6. Press SPEAKER (or hang up the handset).
7. Record the phone number on the memory directory (located under the plastic cover).
ADDING A PAUSE TO THE DIALING SEQUENCE
Use the REDIAL button to insert a delay in the dialing
sequence when storing a number, for example, when you need to dial 9 to get an outside line. Press REDIAL at the point in the dialing sequence in which a pause is required.
Change a stored number by replacing it with a different
number.
DIALING A NUMBER FROM MEMORY
You can dial numbers from memory when using the handset or speakerphone. When you get a dial tone, press the MEMORY DIAL button followed by the memory location (1-9) for the number you want to dial.
Apr 27, 2007 | GE 29318GE1 Corded Phone
Lands Phones Logo
642 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
