Question about Amana Heating & Cooling
I need help selecting the best Amana 5 ton furnace/ac.
I am looking a 5 ton 14 or 16 SEER, single stage compressor.
don't know which evaporator is best.
80% furnace 90 or 105 mbtu
I have a 10 years old Amana 5 ton AC. The service man syas Ineed an new Coil (leaking freon. He quoted $2700 for the cheapeast one. Can I get a better price by shopping around?
Posted on Apr 18, 2010
  • 334 Answers
I believe you are asking which furnace to go with?
Just some clarification first.
The "condensor" is the outdoor unit.
A "Compressor" is the device inside the outdoor unit that pumps and "compresses" the refridgerant.
An evaporator is the indoor coil, it has refridgerant running through it.
The furnace is completely seperat from the condensor and evaporator.
I "THINK" you are saying that you are looking to buy an AMANA system with a 5 ton 14 to 16 SEER condensor, and a furnace, but you need suggestions on the furnace.
typically when you purchace a condensor, the evaporator coil is simply matched by the manufacturer to the specific condensor you purchace, there is no choosing to deal with. All condensors ofcourse come with a compressor already installed.
If my assumption about your request is correct, maybe this will help.
Amana's 90+ furnaces are great units. I would recomend them to anyone. The 80+ uses a somewhat inferior heat exchanger, and is ofcourse less efficient.
Anything higher than a 90+ can take quite a while to recoup the costs of the enitial purchace through your efficiency savings.
If it were my home, I would go with the 90+ furnace, and the 16 SEER Condensor/evaporator system. But ultimatly, its up to you, your efficiency standards and your wallets potential.
If you live in a northern state where AC is little needed, I'd go with the 14 SEER AC.
Again, an initial cost verses long term savings issue.
Posted on Dec 10, 2008
What is the problem with running a 10 SEER condenser with a 13 SEER air handler other than efficiency? I had a 2 ton 13 SEER air handler installed last August to replace one about 27 years old. The...
as most ac units are capillary tube control not tx valve having matched units is critical. as for cost the condensing unit is much more complex and expensive than the evaporator.
Feb 14, 2015 | Amana Goodman R-410A Heat Pump Condenser 2...
How many pounds of reon do you put In 2011 Rheem Classic packaged ac unit
look on the mane plate on outside unit... has voltage ratings model serial type of freon factory charge etc.
Jul 21, 2014 | Rheem Prestige 14 Series 4.0 ton 14.5 SEER...
Purchased Rheem 4 ton 16 seer AC installer just left
Ask your installing company for the AHRI number. If installed with a
matching furnace and coil as listed in the certification then you will get 16 seer rating. If they installed something different than what is listed in the certificate then demand all parts listed or a refund.
Jul 18, 2014 | Rheem 14AJM49A01-RHLLHM4821JA 4 Ton 16...
Lights blinking
The best information you could get is from Carrier. Here's their website:
http://www.carrier.com/homecomfort/en/us/for-owners/
There is a toll free number to call 1-800-Carrier (1-800-227-7437)
Apr 27, 2014 | Carrier Performance 2 Stage 17 Series 2.0...
Carrier infinity 80 won't heat
does your burner flame up and then go put two or three times if so
all you have to do is take out the burner and clean all the soot out of it and then wipe off the sensor
Oct 09, 2012 | Carrier Infinity Series Variable Speed...
Thermostat blank ac wont come on
Hello, some units have a condensate safety switch that will cut off power to the thermostat when the drain line is clogged, A wet/ dry vac must be used to clean out the drain line before the thermostat will receive power again. Amother reason could be either a blown fuse or burned out transformer.
Jul 09, 2012 | Amana 4.0 ton 16 SEER AC / Goodman Gas...
I'm looking to purchase a Rudd 2 stage model, 16 SEER, 5 ton along with a 100000 BTU 95% furnace. I have a two story home and will only be using the 1 AC. Will the Rudd cool both floors?
Assuming that there are ducts ran upstairs and downstairs, it all depends on the square footage of the living spaces, i.e. bedrooms, living room, dining room, etc. You need an average of 1 cfm per sq ft. For every 1 ton of air, you have an average of 400cfms. So your 5 ton unit will cool/heat 2000 sq ft. A 16 seer unit with a 95% furnace is a nice buy and you will notice the difference for sure. Hope this helps!
Aug 03, 2010 | Ruud Central System Air Conditioner
I have a 2 year old compressor and about 4 year old furnance. The Evaporator coil is as old as the house at 20 yrs. My blower had burnt out and my ac was running for a long time and cause the compressor to...
It's gonna be difficult to get a matching evap coil for a 20 year old ac system. Since 2006 all of the evap coil were made to be 13 seer and that caused the size to increase making it hard to install sometimes. If you are going to replace the whole coil, you would be better off if you can swing the money to replace the outdoor condenser and indoor coil at the same time. I know that you only got two years out of the compressor, but everything is going to the new R410A Refrigerant and more efficient systems. You Should Be Able to Keep Your Furnace. Depending On The Climate A Heat Pump Dual Fuel Would Save You A Ton Of Money.
Oct 15, 2009 | Heating & Cooling
After purchasing aGoodman 3 ton l3 seer R-410 AC,
not unless you already had a top of the line furnace. Ask your installer - you'll need papers and info from him anyway.
Sep 30, 2009 | Heating & Cooling
Heating & Cooling Logo
534 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
