Question about Cooktops
Gas Cooktop Igniters Won't Stop
I have a 2 burner GE Monogram gas cooktop, and no matter the knob position on/off the igniters will not stop firing.
Thanks,
Larry
  • Anonymous Apr 09, 2009
    Same
SOURCE: six burner gas cooktop
My husband figured it out.....when we took the knobs off, I, of course, washed the area they had been sitting on, thereby spilling some water into the open part which contained the wires leading to the igniters.  A short time with a hair dryer sorting things out.
Posted on May 07, 2008
textonor
  • 130 Answers
SOURCE: Ge Monogram Gas Cooktop - won't boil water - burners seem like they are starved for gas
Bret, lets give this a try. 1st look at the regulator. There is an arrow on it that has to point towards the cooktop. Put is on backwards and very little gas flow. I always advise this first as I have seen people tell me it is correct and when I got out there it was reversed. 2nd was this used as a live demo unit on Propane? If you are on natural gas, this will also happen. The 3rd thing I also check for in something in the gas line on the cooktop side. I had a unit that got some packing in the line and at 5 wc for natural gas, it doesn't take much to restrict. Hope this helps.
Posted on Aug 09, 2008
SOURCE: Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Posted on Apr 28, 2009
Controlfrk
  • 304 Answers
SOURCE: Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Posted on Aug 31, 2009
heatman101
  • 43501 Answers
SOURCE: GE Monogram gas cooktop electric ignitor will not
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Aug 30, 2010
Igniter will not stop
This indicates an infinte switch has failed or the spark module. First you will need to check each switch. If all switches are working correctly replace the spark module. Here is a link that should help with testing the infinte switches http://appliancehelponline.com/infiniteswitchvideo.html
Jul 23, 2010 | GE 36 in. JGP628 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
all burner igniters work at the same time - you may have a faulty electronic spark unit. change the spark unit. go to repair clinic dot come for the unit. also would be wise to check the ingniter start switch on the gas burner control knob
Oct 17, 2009 | GE 36 in. JGP628 Gas Cooktop
Clicking sound from GE gas stove igniters
u most likely have a gas supply valve problem, the clicking will continue until that is fixed.
Jul 22, 2009 | GE Profile JGP636 Gas Cooktop
Dcs igniters
clean the knob control by using vaccium,pull the knobs then clean it.make sure how to remove the knob,same position to returrn the knob
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Constant sparking
I don't have a Thermador cooktop but here is ma taught.
Could you unplug the two faulty igniters and see if problem remained
Could you plug one of the faulty igniter at the location of a good one. The goal is to isolate the problem. Is it the igniter or the electronic board.
Faulty ground problem may occur also after an spillover on the stove. In that case, use a cotton swab dipped in scrubbing alcool and clean the spark area on the igniter and the burner.
Good luck
Mar 31, 2017 | KitchenAid 31 in. KGCC505 Gas Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
(2) front Burner igniters on my new Matag 30" Cooktop continue to click
Sounds like water got into one of the switches. This usually happens when you wash the knobs. Water stays in the holes and runs down the shaft when replaced. Maytag has issued a recall on some stoves because this can be a fire hazard. UNPLUG THE COOKTOP UNTIL THIS IS FIXED!!!!!!!!! This has happened to me with a whirlpool unit and it tripped a breaker and shot sparks across the kitchen. First go to Maytags web site and see if yours has a recall. If so Maytag will fix it free. While you are waiting leave stove unplugged and light with a match. If you need to fix this yourself disconnect the wires from the two switches this should stop the sparking. Connect one switch at a time and see which switch is bad. Most of the time the electric part of the gas valve can be replaced seperately. and you can do this yourself. If you must actually disconnect a gas pipe unless you really know what you are doing call for service.
May 15, 2008 | Maytag 30" Built-In Gas Cooktop - White
Jennair CCG2523 Gas Cooktop
igniters fire continully any time knobs are on, even after burners
are lighted.
Sep 18, 2007 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Cooktops Logo
240 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
