Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Code F/H My washing machine gives me the F/H error message when I try to run a load. It fills with water and then runs for a few minutes before stopping. After cancelling the wash cycle, I was able to use the "drain/spin" cycle to pump the water out of the machine. Please advise if this is something I can fix on my own (I'm not particularly handy but I can follow directions!) or if I need to call in a professional. Thanks!
  • Carl Wilke Mar 02, 2007
    Thanks for the solution to my problem. It ended up being something else but your advice helped me to be able to at least open up the washing machine.
    President:
  • 878 Answers
Cark, F11 code means that no water is being detected entering the machine or the pressure switch trip is not detected. Usually I find the flow meter to be the culprit when this code comes up. What you need to do first is drop the lower panel by removing the 3 screws that secure it. Right in front you will find the pump filter. Remove the cap and clean the filter. Make sure to have some towels handy for excess water. The flow meter sits on top right in front of the fill valve. It's just a small reed valve that measures the amount of water entering. Easy to change out. Remove the 3 screws in back holding the top on and slide the top back. On the left you will see the fill valve (where the hoses connect) and from there a hose going to the flow meter. First make sure that the hoses going to the washer are not plugged with grit at the valve. Then check that the harnesses to the inlet valve, flow meter and pressure switch are on secure. Another thing to check is to make sure the washer is not siphoning ( draining)during fill. When all is said and done, usually this problem is in the flow meter. Sometimes, the pressure switch itself. I know this is a lot to grasp but at least you know what's going on in the event you have to call for service....Catriver postback
Posted on Feb 27, 2007
  • Ron Marek
    Ron Marek Feb 27, 2007
    Sorry, I meant FH code on the first post...Catriver.
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
Wa75t65gw1
After 2 minutes does the machine throw up an error code. Starts beeping and shows a weird pattern of lights?
If so that error code can help us diagnose what your problem is.
If it does give you an error code take a photo and post it back on here so I can see what it is.
Jul 04, 2017 | Fisher and Paykel Washing Machines
Le error code
The error code "LE" appears after an unsuccessful attempt to fill the drum with water that results in the water level being too low to safely begin cleaning. The product manual suggests calling for service, but there are several steps you can take to try to resolve the issue at home.
Read more: http://www.ehow.com/info_8696564_maytag-washer-repair-code-le.html#ixzz2zXrmqUO5
Apr 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Cabrio: During a white load the machine stops at 38 min
lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
May 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
May 19, 2009 | Samsung SW62ASP Top Load Washer
Kenmore Elite washing machine won't complete a full cycle
its a error code for not enough water fast enoght or no water. check fill bibs are on and screens inside fill valve are clean if ok . make sure you do not have steel branded flow retrickers fill hoses it if so replace hoses. washer has to get a amount of water fast or it will code out
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
Aug 06, 2007 | LG WM-2077C Front Load Washer
Washing Machines Logo
230 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
