Question about GE Profile JGSP44 Dual Fuel (Electric and Gas) Kitchen Range
I have a dual fuel convection range (J2B918) (183D5580P186) The display panel is stuck on :1 No matter what I push on the panel I hear nothing and see no change. Can you help? Thank you
3 Suggested Answers
  • 61 Answers
SOURCE: Electric range displays bake probe
if you need a parts check out appliance parts solutions
Posted on Feb 10, 2010
Daniel S
  • 4323 Answers
SOURCE: We have a GE Profle XL44 Self Cleaning Dual Fuel
Hi
F0 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 08, 2011
How to reset error codes
Dual Fuel Range Error Code 07 ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../dual-fuel-range-error-code-07
Sub?ZeroCore Issue: Dual Fuel Range error code 7; ERR 07 displays on Dual Fuel; Error 07 on control panel of Dual Fuel ... Convection Steam Oven Error Code E75.
L Series Built-In Oven Error Code COMM ERR ' FAQ ' Sub ...
www.subzero-wolf.com/.../l-series-built-in-oven-error-code-co...
Sub?ZeroCOMM ERR displayed on an L Series Built-In Oven indicates a communication error.Reset the unit's power at the circuit breaker. Turn the unit back on to see if ...
WWD30 Warming Drawer Error Code 40 - Sub-Zero and Wolf
www.subzero-wolf.com/.../wwd30-warming-drawer-error-cod...
Sub?ZeroError 40 on a Wolf Warming Drawer. Steps to Verify Issue: With error 40 on WWD30 warming drawer try the following before calling service: ... x. PF Error Code on Warming Drawer ... Whether you're shopping for appliances or have questions about those you already own, we've got the resources you need. ... Wolf Cooking.
Wolf DF304 beeping after turning off the oven - The Kitchen ...
appliantology.org > ... > The Kitchen Appliance Repair Forum
Dec 25, 2015 | Wolf Range Kitchen Ranges
Display panel dim
The display on my cooker started to dim until it finally went dark over a few weeks. Although a different make, I replaced the panel and everything is now fine. I was amazed how bright the new display was so it must have been dimming over a long period.
Nov 01, 2015 | Dacor Discovery ER30DSRSCHNG 30" Slide-in...
How do I unlock the oven door on kitchenaid classical commercial style dual fuel convection range?
disconnect the range form the power source, you should hear a pomp and the door should open
Sep 02, 2014 | KitchenAid Kitchen Ranges
Bake and Convection preheat abort after a few minutes
Hey Jeff Bassler,
How about... Instead of such an expensive experiment
You have a look at some related scenarios cited on
applaincepartspros... My concern is not getting fault codes.
Sorry:
I would need to know your service HISTORY...
SPECIFICALLY: Did this unit ever work?
(to disregard the notion of a FACTORY wiring error)
((proper trouble shooting = ASSUME NOTHING)).
Convection Q&A
http://www.appliancepartspros.com/whirlpool-relay-brd-sheild-12001694-ap4010046.html#qa1
Also see support video (page bottom - same URL)...
Jul 12, 2017 | Jenn-Air JDS9860A Dual Fuel (Electric and...
After baking and trying to set time bake a week ago, the range won't turn on at all. Nothing happens when we press bake, broil, convect bake, etc. The clock, lights, fan, timer and cook top still work.
the oven controller in the main service/selection panel has either a bad solder joint on the circuits or the start realy for the oven on the same circuit board is bad and you have to replace the whole panel you cannot just buy the relay
Jan 20, 2010 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Kitchenaid DF Range F04 error code
I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
Thermador RDSS30 Cooktop works fine. Oven will not turn on. Any button pushed says ''OFF''
My Thermador CT 127 Convection Oven will not turn on. Lights work, convection fan works, oven will not heat.
Jun 06, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
Kenmore Elite Electric Convection Oven Not Working
Check the voltage at the wall Sounds like you have lost one 120 voltage side Red to white should read 110-120 black to white should read 110-120 red to black should red 220-240 check at range and at the wall hope this helps
Aug 25, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Convection oven not working properly???
Model #JMW9527CAQ convection oven has no display visible.Started out very dim and eventually went to no display on the front display .
Aug 17, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Oven door won't open
Hi... Having problems with my Dacor ERD36 as well, I came across this posting that might help with your particular situation of not being able to open the oven door.
Here is the link to the forum:
http://www.applianceguru.com/forum1/2189.html
In case you can't get to the forum link, here is the response:
Have a 2nd person at the circuit breaker turn off power. You press and hold the cooktime keypad. The other person turns the breaker back on. The display will show the 4-character ID code of the ERC (e.g., 1180). You have 30 seconds between each test.
Press and hold these keys on sequence:
convection bake
standard bake
pure convection
broil
timer 2 (momentary push only)
stop time
clock
Finally, we arrive at the test we want:
Open the door, push and hold cook time for 10 seconds. Self clean latch motor will activate. Door latch will complete a cycle. The test will end the ERC will display the time of day.
Complete this test within 30 seconds or you'll get an F0 code (stuck keypad).
I hope this helps.
patti
Dec 06, 2006 | Dacor Epicure ERD36 Dual Fuel (Electric...
GE Profile JGSP44 Dual Fuel (Electric and Gas) Kitchen Range Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
