Question about Car Audio & Video
My clarion drb3675 reads original audio cds but with audio cds I made it displays error 6. Anyone know the reason..
  • mjreed99 Feb 03, 2009
    it says error 6 when i try to play a cd
    Sergeant:
  • 300 Answers
I've found a few comments online regarding that deck saying it's awfully picky about CD-R discs. CD-R's have a much lower reflectivity for the laser pickup than stamped CDs. Some CD-Rs are more reflective than others, though. You might try a few different brands of CD-R and see if any work better.
Posted on Dec 09, 2008
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
My clarion vrx486vd vcd problem
DVD video discs
Audio CDs
video CDs CD TEXT
Mar 22, 2010 | Clarion VRX935VD Car DVD Player
I had a Clarion 6 Disc CAA-355 in my car which got wet and is no longer working. Can I buy the same model again. If so where from and for how much or is there another model that will be compatible with my...
Great Clarion Disk Changer, 6 CDs CDC-655Z:
CDC655z Multi-Disc Changer - 6 -disc direct load mechanism. - 1-Bit D/A converter. - 10 sec. read ahead memory to prevent interruptions caused by shock and vibrations. - Non-stop play. - Optical Digital Output. - 0º to +90º mounting angle.
Great Multi-disk player. Works only with Clarion audio source units.
Selling b/c my deck player broke- I can give you the deck- maybe you can fix it. The model is DXZ-535, comes with owner's manual and remote.
Feb 25, 2010 | Clarion Car Audio & Video
When i put a cd in my DRX7575z cd player it comes up with error 6 i have radio function but no cd
Error 6 means your laser isn't reading disc. Needs replaced pick up laser. I would try first to insert a clean up CD, and test your Cd player with an original CD, if the problem persist, you have to go to fix it to a specialist.
Sep 23, 2009 | Clarion DRX7575z CD Player
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Clarion boat stereo- Error 6
well over time the cd reader in side the unit goes and that what is happen to your unit best solution replace the init
Jul 01, 2009 | Clarion DXZ545MP CD Player
I need a plug for the back of a clarion drb3675 16 pin plug
you might be able to call clarion themselves and see if you can order one through them, if not take a look on ebay they sell harness all the time for this radio.
Feb 22, 2009 | Clarion Car Audio & Video
Clarion DRB3675 cd and radio with clock
to set the clock just press and hold the DISP for 5 to 10 seconds, button while the clock is is displayed. When the the time starts flashing, use the DISP button to adjust the time. When you have the correct time, just hold the button until the clock stops flashing and you're done.
Aug 05, 2008 | Clarion DXZ665MP CD Player
Error code 6 & error code 4
hi try first to insert a clean up CD, and test your Cd player with an original CD, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
sserpentio
May 21, 2008 | Clarion DXZ438R CD Player
Car Audio & Video Logo
225 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
