Question about Rohl A2400 Country Bath TRIM ONLY PRESSURE BALANCE TUB & SHOWER
Water leak outside valve
My Rohl a2400 trim with an ref-2 valve is leaking into the wall when the hand held spray hits the valve.
  • bobj867 Dec 09, 2008
    Phil_m7 Thanks for the thought, We have already done that. It appears the water is going into the slotted holes in the plastic wrin that holds the backplate in place. I have never had this problem in the 40 yrs I have been in the remodel businwss. Has anyone else had this happen? Im working on a Rohl A2400 REP - 2 valve.
    Scholar:
  • 68 Answers
You have a leak where the back plate goes up to the wall OR there is a gasket missing from the trim installation. If this is a tile shower i would suspect the first and use clear tub/tile chaulking to seal around the edge of the plate paying close attention to the grout lines.
Phil
Posted on Dec 09, 2008
Would it be cartridge or something else
Not the cartridge. There are O Rings around the spout that wear out. These need replacing. Call Rohl for replacement parts
www.rohlhome.com/warranty.aspx
Jul 07, 2014 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
No pressur in my home and garden sprayer
You have a leak. First ensure the pressure relief valve is closed. You can try spraying soapy water on the outside while pumping it up, and look for bubbles. The one way valve might be leaking, too. Good luck.
May 21, 2012 | Chapin 2 Gallon Spectracide Sprayer
Our Hotpoint Ice Diamond fridge/ freezer has developed a slow leak, or rather, it collects water condensate on its floor in the upper compartment which then oozes out onto the floor. I don't have a...
Thier are 2 possible thing causing that leak.
1 ) a blocked defrost drain..this tip i wrote will tell ya how to clear the defrost drain
FREEZER ON THE TOP OR BOTTOM http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
SIDE BY SIDE http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
2) the water inlet valve that distributes water to icemaker and in door dispenser (if equipped) hasa pinhole in it and spraying water onto the floor...to check that gotta pull out ref.from the wall and remove lower rear service plate and inspect the valve for a pinhole
GENE
Aug 31, 2011 | Hotpoint Refrigerators
I have a Perrin and Rowe Diverter valve U.5383 for a hand held shower that I need to disassemble to replace the spindle. Is the right hand side housing threaded? There is a hex nut on the housing (exposed...
Soak the unit in very hot water 50/50 with white vinegar for 2or 3 hours to loosen the lime in the threads and try it again. Keep the water hot no boiling but hot.
Feb 02, 2011 | Perrin and Rowe Rohl Bath U-5386 ; U 5386...
Sprayer leaks on my Rohl single lever faucet
The spray head will need replacing, it unscrews and the new one will fit right on
Jun 27, 2010 | Rohl A3608/11LMAPC Single Lever Country...
A GE Profile Model, double door refrigerator with a water leak
If the leak is on the refrig water valve where the wall water line connects to , then use a 1/2" wrench and tighten the fitting on the water valve itself . If the leak is on the plastic tubing at the bottom of the refrig water valve , pull up on the small white ring while pushing down on the plastic tube to remove it from the valve . Cut off about 1 " of the tubing and reinsert it into the valve with pretty good pressure to be sure it is inserted completely .
Mar 27, 2010 | GE Refrigerators
Water dispenser leaking.
The inlet valve will be located in the back of the ref. You have to remove the access panel and the valve will be mounted usually on the right hand side (if your looking at it from the back). To replace the valve you have to shut off the water at the saddle valve probably located in the basement. If you are replacing the valve then I would also replace the saddle valve at the same time its only about 10 bucks, because they usually gunk up w/ calcium deposits which lead to problems with the inlet valve of the ref.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore Refrigerators
Whilpool ed25sm Cold water dispenser leaks
your water valve is bad. behind the ref. in back is a cover. unplung unit remove ref. from back wall about 2-4 ft.remove back cover and you will see a water valve. thats the piece that the hose (your incoming water supply line hooks upto) 1/2 fitting. turn water suppy off. remove screw holding valve. disconnect wires one bye one and hoses one bye one.(so you dont mix them up).if your ref has a inline water filter and has not been replaced in a while i woiuld try that first. valve is about 45-85/ depending on your model ,i do not have that.and labor roughly 75-125 to replace depending on were you live and who you use. hope this helps you.
Sep 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Leaking outdoor hose bib
ok this is an easy one.  you have what is called a  frost free hose bib.  this is split or has a hole in it after the seat.  the seat is inside the house wall.  you need to cut off the copper inside the house and replace the valve .  if it is not a solder joint than have someone hold back on the copper on the inside and you should be able to spin it off and replace it.  P.S if this is the case make sure you use T-tape on the threaded conection
Jun 21, 2009 | Plumbing
Water won't come thru the faucet.
dirt in the screen before the sprayed handle, shut off vakve clogged under sink, is this something that just happened? where is the check valve located is it in the hand held or under the sink,, if in the hand held take a needle and clean it out, or call the company and have them send out a new one
May 30, 2009 | Plumbing
Rohl A2400 Country Bath TRIM ONLY PRESSURE BALANCE TUB & SHOWER Logo
222 people viewed this question
Top Rohl Home Experts
john h
Tom Chichester
Are you a Rohl Home Expert? Answer questions, earn points and help others
