Question about Brother SX-4000 Typewriter
Brother SX-4000 Lettes that print are not same ones I press
When I type a the number 1 comes up. It is all typing a differnt key that the one I chose.
  • Anonymous Mar 02, 2009
    When we type, the first few words type correctly and then it goes into a jibbersih mode on its own. HELP!
  • 4 Answers
I found a complete owner's manual to print at the following address: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_SX4000_EN_219.PDF
Posted on Dec 16, 2008
How do i get my Brother A X 250 Eletric Type writer to type the correct letters ?
"If your unit is not printing properly:
1.Ensure the ribbon cartridge has not run out of ribbon. If your ribbon appears silver or gray, install a new cartridge.
2.Ensure the black lever in the center of the carriage is pressed to therear towards the paper. If not, press it to the rear to lock the Daisy Wheel into place.
3.Reset the unit by holding down the [CODE] Key and pressing the [SHIFT]Key and the [WORD OUT] Key.
4.Release all three keys.
5.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
Feb 27, 2013 | Brother SX-4000 Typewriter
When i type letters they come up with other letters that don't correspond with the keys I hit. I have the brother sx-4000
If you aren't in KBII or a language mode or P.S. pitch the printwheel homing pawl is probably broken. You need a tech.
DickyO
Jun 14, 2011 | Brother SX-4000 Typewriter
I began using my typewriter this morning...and when I press a number or letter...it types the wrong number, letter, or symbol. For example, I press the letter "F" and it types a number...
Turn it off and on it should go thru it's dance and rehome the print wheel. f you are notin KBII , language mode or the print wheel damaged the homing pawl for the P/W is probably broken you need a tech.
DickyO
Jun 09, 2011 | Brother SX-4000 Typewriter
How do I download brother SX-4000 electric typewriter?
If you are asking how to download to a computer file or a storage device, there is not a way without a major modification to your hardware (commonly known as a HACK to the device). Brother did not include a way to download from memory to a computer file.On the other hand, if you want to print what you have on the LCD screen you are typing in display mode. There are 2 typed of display modes (Line by line, and Auto) The way to print in display mode is;
  1. Press return if you are in Line by line.
  2. Type a complete page with and the machine will add the return when you reach the Right Margin.radarron_1.jpg
To determine what mode you are in, on the right side of the display you will see the operate section (see attached diagram) . If the triangle is pointing up you are in "Auto Return", if it is pointing down you are in "Line by Line" mode. If you don't see a triangle it should type as a normal typewriter (each letter as soon as you type it). To toggle through the modes hold the ALT key and press the OPERATE key. The keys that are activated by the ALT are color coded (same color as the ALT key) and are across the top of the keyboard.
Feb 15, 2011 | Brother SX-4000 Typewriter
HOW CAN I TYPE IN UPPERCASE AT THE SAME TIME AS TYPING NUMBERS FOR EXAMPLE ABC123. IT'S ON A BROTHER SX-4000 EXLECTRONIC TYPEWRITER
I am sorry to tell you that your machine does NOT have that function.
This is the difference between Shift Lock and Caps Lock.
1) Shift Lock is the traditional upper case used since the oldest mechanical typewriters
2) Caps Lock (what you want) works like a computer, where you get upper case Alphas and numbers.
Brother does include this feature on some models, but I am sorry to say not yours.
If this helps you, PLEASE log back on to this webpage and leave comment. It's nice to know that I am helping someone and not just wasting my time.
Ron
Jul 16, 2010 | Brother SX-4000 Typewriter
Is there a way to set typewriter to type numbers and uppercase?
There may be a caps key. You can get a manual @ brotherinternational.com, click on support.
DickyO
Apr 20, 2010 | Brother SX-4000 Typewriter
Types funny symbols instead of the number I
The typewriter will print the incorrect letter, or the face of the hammer if it does not spin properly to the correct position. 1. Turn the machine offf for 15 seconds and turn ON, or Depress MODE RESET(the Q key). This will rehome the Daisywheel.I If it prints correctly for awhile then looses its' position, check for ribbon or correction tape interference with Daisywheel movement. If it does not print correctly as soon as you start typing, remove the Daisywheel and inspect the spokes to see if any are bent. Reinstall the Daisywheel and power ON. If the Daisywheel has a bent spoke or two, you can try to straighten them, howvever the cause of bent spokes is a concern. While typing, carefully watch the print hammer movement. It should always return to the same position and not move towards the paper until a letter is pressed. If it does not come to rest properly, the hammer is not in proper timing and may enter the Daisywheel while it is spinning to the character, thus causing damage to the Daisywheel or causing it to lose homing. .The hammer cams would require adjustment ore replacement. If bent spokes is a persistent problem, make sure to get the hammer problem repaired before buying a new daisywhel.
Dec 29, 2009 | Brother SX-4000 Typewriter
Typing in jibberish when i type a letter
Hold down the CODE key and the "L" key (says 'lang' underneath the "L")
Feb 16, 2009 | Brother SX-4000 Typewriter
Brother SX-4000 Typewriter Logo
107 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
