Question about Lexmark Office Equipment & Supplies
Message reads 'cover open' when it is closed. Printer inop.
    Scholar:
  • 162 Answers
Possible cause of the error
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
What to do
Try to determine if there is a hardware fault. To do this:
    1. Disconnect the power cable and the USB cable.
    2. Remove the cartridges from the printer.
    3. Check that the power cable is plugged directly into a wall socket.
    4. Reconnect the power cable.
    5. If the error persists, please contact Lexmark Technical Support for further instructions.
Posted on Dec 09, 2008
How can i fix Cover open Error message for canon multipass mp360
The message indicates that the printer door or the cover located on the top is not closed properly, so you need to re-open the door or the printer cover and close it accurately.
GuruAid.com
Mar 09, 2016 | Canon MultiPASS MP360 All-In-One InkJet...
Message reads "cartridge short press power key"
The error indicates that one or both of the cartridges has a short circuit. Please follow the steps below to identify and fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 11, 2011 | Lexmark X83 All-In-One InkJet Printer
Canon MP830 printer giving error message "inner
If the inner cover is open when starting normal printing,close it before pressing [OK] on the machine.Do not open or close the inner cover when printing.This may damage the machine.
Jun 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
When I try to print, I get the error: Top Cover Open: The printer cannot print because the top cover is open. How do I fix this?
Hi cduckyquack ,
  • All you need to do is close the printer cover if it's open , once it's closed you should be able to print correctly without any warning messages.
  • If the cover is closed and still you are getting the same message , then it might be a problem with the censor switch which indicates to the printer whether or not the cover is open, so if the switch / sense has gone faulty then you need to repair it.
  • Sometimes just because of dust the printer does not sense the cover being closed and it results in the error message that you have described.
  • Hope this helps ...) your feedback would be appreciated.
Jun 02, 2011 | HP DesignJet 1050c plus InkJet Printer
My printer reads cover open however the cover is closed. this error message occurred after the ink was changed. What am I missing?
Why don't you turn off your printer and restart.
What's the error code? There should be some letter on LED display.
Apr 11, 2011 | Canon PIXMA MX310 All-In-One Printer
Text on the display: back cover open,close the Back Cover we close the cover but no results
If you turn the printer off and then back on when there is a paper jam in it you will get this error message instead of a paper jam message. To clear the paper jam from the back of the printer read the instructions from here: http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000600/000096/faq000696_001.html?reg=us&c=us&lang=en&prod=mfc7420_all&Cat=11
Feb 25, 2011 | Brother MFC 7420 All-In-One Laser Printer
Message 'Clean Sensor' has appeared. Followed advise to open Cover D and close it again but to no avail. Has anyone got any other suggestions, please?
Follow the steps below to clear the "Clean Sensor" error message.
  2. Slowly close the cover again. c2600_close_cover_d.jpg This action will move the lever shown below and clean the sensor.
  3. Open and close the cover several times. Once the front cover is left closed the printer will start to calibrate.
Once complete, the error should no longer appear and the printer should resume normal operation.
Note: If the error message is still apparent after following the steps above, contact Epson for further advice.
Nov 16, 2010 | Epson AcuLaser C2600N Printer
Hp 7410 officejet all in one
--close cover ---means the lower base of the printer is open the cover you open when to remove or insert the cartridges.that is not related to copy or scan cover which is above that.just close the lower covwer little bit tightly.apply gentle force or push to make it close properly.
do it carefully.
thanks.
Sep 15, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Error mesage
No solution, but I have the same problem. THe printer starts up fine, I hear no grinding noises or other "funny" nioses, and then displays no error message... UNTIL I ask it to print. Then I get a message that says, "Pls (please) Open Cover".
I open the cover and it says "Please Close Cover".
I close the cover and it says, "Please Open Cover"
and this happens forever!
Does anyone have any ideas? Can anyone help me?
Stefan
Mar 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
37 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
