Question about GE Refrigerators
Not cooling ge model gss25jfmbww refrigerater evaporator fan in freezer not running, bought new fan sill not running
  • Anonymous Mar 25, 2014
    continues to run for a long time all below parts are clean cold freezer and refrigerater
  • Anonymous Apr 01, 2014
    model kbfs22ewms7 temperature not holding at settings freezer and refrigerater
  • 1,543 Answers
Sometimes when the evaporator fan goes out, it takes part of the motherboard also. (part number WR55X10552, which also subs into a WR55X10656) If this is the case, I would not expect the refrig to be running either. (If your compressor still runs, check door switch.)
Posted on Dec 09, 2008
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Started leaking water out the freezer door and ice was melting last nite... bad timing we just got a snow storm here in NC last nite. Seems to be running but food is defrosting. Its a GE Side by Side about...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jan 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a ge gss22kgpacc side by side, the freezer is working, lights, etc. all working, but the refrigeratoe side is not working, any insight? thanks, mike
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hope this helps good luck ron
Dec 12, 2009 | GE Refrigerators
Refrigerater is not cooling
The refrigerator gets air from the freezer. Look in the freezer for frost. If you have frost in the back or bottom the you have a defrost problem. Could be a timer or heater that is bad. If no frost do you hear a fan? You should have a evaporator fan running. Maybe thats out and it not circulating air for the refrigerator. You can check this out.
Hope it helps
Aug 17, 2009 | Whirlpool Refrigerators
PTS25 Top Freezer Model- Fridge & Freezer won't cool
If the compressor is still good your hard start relay might be bad.
Aug 05, 2009 | GE Profile Arctica Stainless Steel Top...
Freezer works fine fridge won't cool below 43deg
COULD BE EVAPORATOR FAN MOTOR. WHEN FREEZER DOOR IS OPEN CAN YOU HEAR A FAN RUNNING NEAR THE BACK WALL OF FREEZER SECTION?
Jan 29, 2009 | GE PDS22SIS Bottom Freezer Refrigerator
Freezer is cold but refrigerator is not?
In new models the freezer also cools the refrigerater with a fan. you have to call a repairman to do this work. he has the equipment to test the fans.
Aug 20, 2008 | GE Refrigerators
Fan works light works but no cooling in either the freezer or refrigerater
The fan in the back of frig will run. Try replacing the evaperator fan and if the evaporator fan does not work replace the thermostat.
Jan 09, 2008 | Kenmore 53092 / 53094 Side by Side...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
387 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
